Is it possible to configure a “smart” backup strategy, ie, keep some of the mid term backup instead of loosing everything after a while? For example, on my Synology, I can have:
backup are done every day, we delete old backups after n days, keeping only n latest backup available, BUT…
the system ensure to keep m monthly backup AND…
and p yearly backup as well.
The algorithm is a bit more complex, but the general idea is here.
I have made a mistakes during configuring the lovelace UI, and did not see it after a while, so I have lost my custom card, because I do not have a 1 month-old backup (and i would be happy to have a 6 months old backup as well).
Approach 1 - Setup a folder on your synology, periodically (1x day) copy your HA config folder in along with the hidden .storage directory. Then use synology to back this up.
Approach 2 - if you are a GitHub user, setup a repo and use this to store your master config. I like this since it allows me to view diffs on what has changed in files and to review changes before deployment.
I’ll second the Samba Backup add-on (Supervisor add-on). It works great for exactly what you want and since it’s an add-on it’s mostly part of HA already. I’ve been doing this ever since I discovered that and have had to rely on it a couple of times to get a backup from a couple of days ago.
