I have 2x the ssp-h-20-1c.
Can you place me on the list for 2x the module?
If you have a part list, software and the print lay-out. It's no problem to solder it by myself.
I use homeassistant
I use homeassistant
Summer is coming !
Can you put me on the waiting list too ?
Model : SJB-HS-22
Using Home Assistant.
Thanks,
Vincent
Bonsoir!
Recently I bought a SB-H20-1, the one with the salt system..
As far as I know this one is not compatible yet?
Keep up the good work !![]()
Gr Bobke
So I have some good news and some bad news.
First, the bad news: I’m completely out of stock, and the worst part is that restocking is complicated given the current situation. I’m trying to find alternatives... So if I succeed, I might be able to ship starting June 20 (theoretically); otherwise, it will unfortunately be in August...
Now for the good news: the new SB-HS20 spa is fully compatible. It was a lot of work because INTEX completely overhauled its internal communication protocol... I’m fine-tuning the 7.X.X firmware, which will support this spa in addition to the other two spa models (SB-H20 / SB-B20 / SSP-H-20-1C / SSP-H20-1G / SPJ-H-20-1C) and the SJB-HS). I’ll update the first post with this new compatibility information when I’m ready to ship.
@Johnvanlimpt @joep1222 @vdeconinck @Bobke77
I'll put you on the waiting list.
I'll let you know when I'm able to deliver it ![]()
Hey that's amazing! great work. Could i still put myself on the list please?
I have the SB-HS20-1 as mentioned before and am using HA.
ok I'll put you on the waiting list.
hey how much would the sb-b20-1 i think its one i have its one from alid
Hi do you sell these still to the uk?
sb h20 intex
Hi, I am interested in you wifi solution. I have a Intex SB-H20 (3 years old) and I am using Home Assistant. I am from Belgium. Can you sent me a PM with the details ?
Hi @Jenno666,
I haven't quite got the full picture, but you probably have an SB-B20, is that right?
And do you have Home Assistant?
Hi, yes i can send it to the UK ![]()
Do you have Home Assistant ?
OK, I’ll put you on the waiting list and I’ll get in touch with you and everyone else on the list when I’m ready to deliver.
I’m still waiting for some parts to finish the assembly...
