Smart Home Automation for INTEX Spas – WiFi & MQTT Control!
Oh, well, I must have sent it somewhere else... It should have been sent correctly ^^
Hy @PaTiTan,
I‘ve the following spa
and hope your electronic is also compatible.
Can you send me a DM with more details please?
Hi, did you use Home Assistant ?
This SB-HS20 is compatible :wink:
Yes I‘m using HomeAssistant
No news yet ?
I'm sorry, I think I may have forgotten you :confused:
Please check your private messages
Hi @PaTiTan,
I have an Intex PureSpa 28428EX (SB-H20) and I’m interested in purchasing one of your Home Assistant controller modules. I can’t send you a private message yet because my account is new. Could you please contact me or let me know how I can order one? Thank you!
Hola. Tengo un spa sb-hs20-1 y Home Assistant. Estoy interesado en tu sistema. Vivo en España. Cómo podría obtenerlo?. Muchas gracias.
Hi PaTiTan,
i have a Intex SimpleSpa with Model SB-B20.
Is the module suitable, and is it possible to integrate it into Loxone? UDP/MQTT/etc.?
Costs incl. Delivery to Austria? :grinning_face:
Hi @PaTiTan !
I would like to purchase your Home Assistant controller unit for my Intex PureSpa SB-HS20-1.
Could you please contact me via private message?
Thank you!
hey @PaTiTan i found i dont have the jsp connector on mine can you pm me as i have the mico controller but appear
i might need to cut cabling
Good evening @Woif and @Jenno666
I recently sent a system to a user who has an SB-B20, and because of the latest update (which added the SB-HS20), the SB-B20 no longer seems to be compatible. I’m trying to find this model so I can reverse-engineer it. Sorry for the inconvenience.
hi @PaTiTan i can send you all pictures of it if you require as i have had it apart and from screen to motor there is 5 cable, where is best place to send videos and pictures to you
@PaTiTan hi hey sb-b20-1
Hi PaTiTan,
I’m really interested in your Intex spa control box. Could you let me know if you have stock available and whether it’s possible to ship to the UK?
My details:
  • Spa model: Intex SB-B20-1 (SimpleSpa)
  • Home automation system: Home Assistant
I’ve been trying to build a DIY ESPHome solution myself but ran into some reliability issues, so a pre-built solution that connects to the original connectors (no cutting/splicing) sounds ideal.
Could you send me the details by PM, including current price and shipping cost to the UK?
Thanks very much!
Hi @PaTiTan
Definitly interested in your product!
I hava a SPP-H-20-1G and use home assistant.
Hope you still have stock!
Thanks in advance!
There was no need to open up the engine that much because I’m connecting to the connector linked to the screen—just make sure you have it, though:
And @Jenno666 and @dorr14 The problem stems from an incompatibility between my latest firmware and your SPA. I need to get my hands on your model to figure out what’s causing the issue. Until then, I can’t send you the system.
@PaTiTan you might struggle getting hold of it because it was Aldi that sold it so I believe it was a model just for them. There is five wires that go from the screen to the pump but they are in coloured so was going to cut them probe then find the ground find the live and connect them into the module
Hello, can i still order a control module?
SB-H20 and HA
Ship to Belgium
Thanks in advance
