Hi PaTiTan
Yes I am using home assistant
I’ve send you MP ![]()
I’m very intrested in this project.
In what language will the data show in Home Assistant?
Would it be possible to get information about ordering?
I have a Pure spa SSP-H-20-1G and using Home Assistant at the moment.
Thank you in advance, Bryan
Hello ![]()
in your language
parfait !!
i will send you MP
Hello kind sir,
I am interested to order this module to connect it to a SJB-HS-22-1G and control and read it through Home Assistant
edit: did a quick check, the model has the 5-pin connector.
Kind regards,
Arjan
i send you a message too ![]()
PaTiTan
Everything is in the description of the first message ![]()
You can control the spa directly with Home Assistant and set up automations (for example, on weekends or when the sun is shining, the spa heats the water and is ready for me to take a dip).
If you’re interested, I need to know if you have a home automation system (Home Assistant, for example
) because the spa is compatible with it.
If so, I’ll send you a private message with the details.
Big update tonight for my firmware, which is going from version 4.0.0 to 4.5.0.
Local web page preview:
Added a digital display like the one on the spa control box.
Appears just below the error message if the spa is experiencing an error, and is even translated.
Choice of spa model and user language in the configuration menu.
Addition of an “OTA update” button (no need to remove the Wemos to perform updates).
Addition of a “programming” button (it takes precedence over Jeedom and HA, mainly for those who have neither:
A redesigned button to reset to factory settings with confirmation
Quick access with the QR code if you are configuring with a PC and want to control the spa with a smartphone and bookmark the page
A new, more optimized PCB; it couldn’t be any smaller.
Display of the firmware version and local IP
I’d love to order one for my SB-H20 pump as well.
Do you’ve in stock?
Best
Chris
Hello, yes, I have enough stock for the whole year. I’ll send you a private message with the details.
#PaTiTan how i can buy this magical box. Write to my on PW
Welcome to the forum. I’ve sent you a PM.
