Hello, and thank you for the compliments—it’s always nice to hear. Yes, I can ship to the UK; I’ll send you a private message with the details.
Please write I can used wifi module ?
I’ve been building these systems for Intex spas for nearly six years now, and this is the first time I’ve seen this “SPJ-H-20-1” model…
I need more information:
What year is it?
What country is it from?
Is there a connector in the pole?
Year maybe 2018
From Poland
Hi @PaTiTan
I also have the SB-HS20-1.
If you’d be willing to send me a kit, I can probably spend some time to track down what needs to be adjusted for it to work with this model.
Let me know.
Year 2019
Poland
Collector pole the same
Hi @marogr6173 ,
According to the instructions, the screen connector might work with my system. Would you like to give it a try?
And if it doesn’t work, you can send it back to me and I’ll refund you (minus shipping costs). Does that work for you?
Hi Albianto,
The problem is that to successfully decode the code frames, I needed an oscilloscope, and without the SPA on my desktop, I wouldn’t be able to do anything…
I can still send you a system, but it’s very likely you won’t be able to do anything with it ![]()
I understand. I’m pretty confident around oscilloscopes and code, I can give it a try.
Hello @PaTiTan, I have SB-H20 Spa and home assistant … Do you have controller available? I’m from Slovakia
Honestly, I wouldn’t be able to help you effectively from a distance, and I’d feel bad if you spent money on something that might never work ![]()
ok, i send you MP
Mostly interested in getting the hardware I can use to do the adaptation work.
Can you send me a kit half price or something like that?
If the code is open source, I will contribute the necessary fixes there myself.
Hi
PaTiTan
Of course. Please send me information.
I will pay.
Thank you very much indeed
Marek
Did you write me a message? I didn’t find it in the website here. I would buy one please. Thanks
@PaTiTan Hi, I would like to purchase one controller. I have an SB-H20.
Hi, did you have Home Assistant ? and where are you from ?
Yes, of course. From Hungary.
