Smart Home Automation for INTEX Spas – WiFi & MQTT Control!
Am I be of help with taking pictures etc?
Oh no :sad_but_relieved_face:
Can I provide you some info or data? I was fiddling around with another GitHub repo, so I used a esp32 and a LC12S but couldn’t get it to work.
no :confused: i need to open it and doing retro-ingenering
With the wireless control panel, there's nothing to plug my system into :confused:
Could you send me a unit like that? I would like to order one. I am from Germany.
Hi, Witch model of spa do you have ?
Did you have home assistant ?
Hi PaTiTan,
I’m interested in buying your WiFi/MQTT controller for my Intex PureSpa SB-H20 and using it with Home Assistant in the Netherlands.
I’m currently unable to send private messages on the forum. Could you please contact me or let me know how I can reach you?
Thank you!
Stijn
Hi @Boesje , check you MP :wink:
Hello, my pool is an Intex SB-H20, and I own a voice assistant (Google Home). Could you please send me a private message?
The spa is fully compatible, but Google Home isn't a home automation hub like Home Assistant. This means you'll be limited to using it only with your phone or computer when you're connected to your local Wi-Fi network.
Is that okay with you?
In any case, you can install Home Assistant whenever you like.
Yeah, no problem at all—I'll just do it via Wi-Fi. It works via MQTT as well, of course; I'll have to look into that sometime.
Ok super, i'll send you informations
Hi PaTiTan,
i´m looking since a long time for a "ready to run" Solution for my INTEX SB-H20 and HomeAssistant. If you would sell one to me, i would be very happy :wink:
Ok, I will send you information
Hi, i have a sb-hs20-1 to. Wil it ever be compatible with your product? And if so do you have some eta?
Thanks!
I'm sorry, but as I mentioned earlier in this conversation with three other users, the SB-HS20 isn't compatible yet... sorry
I’m aware that it is not compatible at the moment. But my question is wil it ever be?
Sorry, I didn't read your sentence carefully :confused:
So I have no idea. I'll have to find one myself to reverse-engineer it.
I get the impression this is the new generation of spas, so it would be great to make it compatible
I tried it with two French users remotely, but I couldn't get it to work.
I need to take one apart at home, so I'm currently looking for someone who has one not too far from where I live...
Where's that at? I'm from the Netherlands. I asked Ai what the difference might be and it said it was probably the bit length due to the sanitizer/salt water system .
