Smart Home Automation for INTEX Spas – WiFi & MQTT Control!
That's right, this spa has that little difference—a nice touch on the part of the AI—but in that case, my system would have worked for all other commands except the sanitizer/salt ones. And it would have been easy to release an update to implement this new feature.
But the spa reacts completely differently. On HA, Jeedom, or my local web page, all the statuses change together every second (ON --> 1s --> OFF --> 1s --> ON --> 1s --> OFF) and no commands work. It’s as if the synchronization frequency were completely different. That’s one of the things I’ll look into if I get my hands on a SPA.
So remotely, there’s nothing I can do.
Paris France
The 1-second ON/OFF rapid toggling seems to be a frame desynchronization loop caused by a hardcoded bit-count buffer limit overflowing. If you update the firmware to use a clock-silence timeout (gap detection) to mark the end of a frame rather than a strict bit-count, it should stabilize the data stream. I was planning on getting a USB logic analyzer to dump the exact frame size and bit-masks so i could see if i could make it a DIY project for myself and build my own box, hence the ai help. but I'd rather help you out and not have to deal with another project.
@PaTiTan, do you still have these modules in stock? Looking into making my spa smart with my ha setup.
Good evening, I'll send you the details via PM
hello @PaTiTan , I have a SB-H20, around 2 years old.
Can you send me a unit to Belgium?
Hi, do you have Home Assistant? It's not required, but it's better :wink:
Hey, i'm interested in one module - got the SB-H20 and Homeassistant and ESPhome setup.
Got one questions though, didn't find it in the thread:
Is it only possible to turn heating on/off with full energy consumption OR is it also possible to have a more energy saving heating enabled - e.g. reduced consumption - 1kW , i know it would take longer to heat completely.
BR
My system is just a remote display of the control panel, so no.
What you want to do is complicated because you’d have to directly modify the heating elements using a contactor to limit the heating power (assuming the heating element is an assembly of at least two or even three elements in parallel). It’s definitely possible, but you’d need to be a very skilled DIYer to pull it off.
Are you still interested?
Thanks for the quick reply, unfortunately not interested anymore - although you did a great job with this DIY!
Just received the controller and already integrated it in homey! Thanks really happy with it
Hi PaTiTan,
It would be very nice to controll my purespa with HA.
Is it possible to sent one of your very nice creations to the Netherlands :slight_smile:
yeah of course, check your MP :wink:
I am interested in purchasing your solution.
I have an INTEX SB-HS20-1 that I would like to control via Home Assistant.
Will that Work?
Do you have them in stock, and what are the next steps?
I have an INTEX SSP - H - 20 -1C that I would like to control via Home Assistant.
Hello, im intrested for the module for my model. Please provide information. Im in Germany
Im working on this new model, you have to wait^^
I have 4 system in stock, check your MP :slight_smile:
first come, first served
Hi, check you MP,
The waiting list is now open for those who didn’t receive a PM :wink:
If you’d like to be added to the list, please include the following in your message here:
  • Your Spa model (to make sure it’s compatible)
  • Your home automation system (not required but preferred)
I’ll confirm your spot on the waiting list and contact you as soon as I’m ready to ship.
I’m really sorry about this waiting list, but this year there have been so many more of you than in previous years...
Okay, when you have it working on my device, I would like to order one.
