Some work is required in this upgrade see below.
Upgrade Features
Ambient Light Sensor: We have now added a LUX value for ON and OFF. You can now set a dead ban so you light doesnβt turn ON and OFF to fast on a cloudy day.
Below shows the OFF value higher than the ON value. This will work
Below shows the ON and OFF values equal. This will work
Below shows the OFF value lower than the ON value. This will not work
STEPS REQUIRED WHEN UPGRADING
If using Ambient Light Sensor then you will need to set your OFF value. Below shows a dead ban of 80 lux.
If you would like to keep it the same before this update then set the OFF vale the same as the ON value. Below show the setting the same as before the update.
If you like this blueprint? Consider hitting the
button in the top post
If you like my blueprints, and would like to show your support or just say thank you? Click Here
Enjoy
Blacky
