chipped
(Thanasi)
1
I am using Zigbee2MQTT to bring some smart plugs with power monitoring into Home Assistant.
I can only see Energy consumption as a Sensor which is the amount of kWh the Smart Plug has consumed over its lifetime.
Instead I’d like to be able to show Power usage.
When I go to Settings > Devices & Services > MQTT > Devices > Go into one of my Smart Plugs, I can see the Power sensor in the diagnostics section.
I’d like to show this on the device in the dashboard.
How can I change this to add it as a sensor to the Smart Plug?
Thanks.
koying
(Chris B)
2
Do you mean the auto-generated dashboard?
Because you can use a diagnostic entity like any other on a custom one.
chipped
(Thanasi)
3
I’m new to home assistant so I’m not familiar with Dashboards yet. Is there a way to change the entity so it’s not Diagnostic?
chipped
(Thanasi)
4
Just an update, I have to Edit my dashboard and “Take Control”. After this I was able to add custom cards which can include diagnostic entities.
