Hi All, Firstly I’m very new to Home Assistant so please forgive me if I ask dumb questions but i’m getting there.
I wanted to get some Tuya smart plugs (Gosund UP111) running locally and with power monitoring in home assistant. I believe I have two options Tasmota and ESPHome.
I’ve managed to get Tasmota on a test device but this requires MQTT which I don’t have setup yet. So I looked at ESPHome, i’ve added the Home Assistant integration and compiled the following binary;
substitutions:
# Unique ID for Sensors.
switch_id: "plug_washingmachine"
# Higher value gives lower watt readout (0.0025)
current_res: "0.00221"
# Lower value gives lower voltage readout (880)
voltage_div: "955"
esphome:
comment: Gosund UP111 - Washing Machine
platform: ESP8266
board: esp01_1m
wifi:
ssid: "<WiFIAP>"
password: "<APPassword>"
# Enable logging
logger:
# Enable Home Assistant API
api:
reboot_timeout: 0s
password: '<ESPPassword>'
ota:
time:
- platform: homeassistant
binary_sensor:
# Push Button
- platform: gpio
internal: true
pin: GPIO3
filters:
- invert:
on_click:
min_length: 50ms
max_length: 350ms
then:
- switch.toggle: ${plug_name}_out_relay1
# Template Sensor - Tracks Relay, Switches LED to Match (Internal Only)
name: "${plug_name} Template 1"
internal: true
lambda: |-
if (id(${plug_name}_out_relay1).state) {
return true;
} else {
return false;
on_state:
- if:
condition:
- binary_sensor.is_on: ${plug_name}_template1
then:
- switch.turn_on: ${plug_name}_out_led
- switch.turn_off: ${plug_name}_out_led_red
- if:
condition:
- binary_sensor.is_off: ${plug_name}_template1
then:
- switch.turn_on: ${plug_name}_out_led_red
switch:
# Restart Switch in HA
- platform: restart
# Relay Output
- platform: gpio
pin: GPIO14
#restore_mode: ALWAYS_ON
name: "${plug_name} Relay 1"
# Blue LED Output
- platform: gpio
pin: GPIO1
internal: true
inverted: yes
name: "${plug_name} Touch Status Led Blue"
- platform: gpio
name: "${plug_name} Touch Status Led Red"
pin: GPIO13
inverted: True
internal: true
restore_mode: ALWAYS_OFF
- platform: hlw8012
sel_pin:
number: GPIO12
inverted: True
cf_pin: GPIO04
cf1_pin: GPIO05
current_resistor: ${current_res}
voltage_divider: ${voltage_div}
current:
unit_of_measurement: A
voltage:
unit_of_measurement: V
power:
unit_of_measurement: W
change_mode_every: 8
update_interval: 10s
- platform: total_daily_energy
name: "${plug_name}_Total Daily Energy"
power_id: "${plug_name}_Wattage"
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
unit_of_measurement: kWh
# Extra sensor to keep track of plug uptime
- platform: uptime
name: ${plug_name} Uptime Sensor
# Wifi Signal
- platform: wifi_signal
name: "${plug_name} WiFi Signal Sensor"
update_interval: 60s
Which was 99% stolen code from other posts and it validates, I’ve checked all the GPIOs against Tasmota and I think the platform and board are correct but Tasmato refused to flash OTA and when flashed through Tuya_Convert it bricked the plug, so something isn’t right!
If Tasmato is the way to go then I’ll persist with getting MQTT setup but for this use ESPHome does seem smarter and MQTT seems a bit of a learning curve.
Any suggestion, help would be greatly appreciated.
