Smart SolaX Automation in Home Assistant - with self learning
A fully automated energy-optimisation suite powered by ChatGPT + Home Assistant
If you’re running a SolaX inverter system, switch between Octopus Energy Flux and Cosy tariffs during Summer and Winter months, and want Home Assistant to manage it intelligently — I’ve published my full working setup on GitHub :backhand_index_pointing_down:
:link: SolaX Automation in Home Assistant
:high_voltage: What It Does
This automation suite manages your SolaX hybrid inverter system to:
  • :white_check_mark: Minimise Grid Charging
  • :white_check_mark: Minimise PV Clipping
  • :white_check_mark: Maximise Export Revenue
  • :white_check_mark: Run a Free Energy Session Controller
  • :white_check_mark: Run an Energy Saving Controller
  • :white_check_mark: Include External Temperature Compensation
  • :white_check_mark: Automatically switch between Octopus Cosy & Flux tariffs
:magnifying_glass_tilted_left: Learning Layer — Continuous Optimisation
At the core of the system is a robust automated learning layer that continually improves accuracy between forecasted and actual performance, learning from:
  • :sun: PV Generation
  • :high_voltage: Daily Demand
  • :crescent_moon: Evening Demand (especially useful for ASHPs and the Cosy Tariff)
  • :snowflake: Minimum Daily Temperature (anticipates increased heating usage)
This learning layer automatically adjusts the system’s bias over time, keeping forecasts and plans realistic while protecting battery charge levels and grid-import costs.
:house_with_garden: Tested & Proven Setup
Designed for both single and parallel inverter systems — tested live with:
  • 2 × SolaX X1 Gen4 Hybrid Inverters
  • 2 × 11.2 kWh battery banks
  • Fully compatible with any SolaX Modbus-enabled inverter (just map your entities and create the helpers).
All code is stable, production-tested, and running daily in my home.
Installation steps are included.
:speech_balloon: Linked Chat — How to Build YAML with ChatGPT
I’ve also documented how I used ChatGPT to generate and manage all my YAML automations:
:link: ChatGPT-HA-Docs on GitHub
Please Note: This isn’t a product — just sharing the result of months of development and testing to help others streamline their energy management.
Would love to hear how it works for you — feedback, tweaks, or integrations welcome! :rocket:
Would this work for other region and difference in grid Import and export pricing?
Sorry, I missed your message. Yes it should do if you can change the tariff parameters.
Hi Simon,
Your solution looks very interesting, especially the logic and the overall approach.
I have also tried controlling the SolaX inverter based on forecasts and export tariffs, but my logic is not as sophisticated as yours. That is why I am considering using your solution as well.
However, what I see as a potential weakness of your solution is the use of inverter state switching, where the changes are written to EEPROM. I am concerned about reaching the allowed write-cycle limit over time.
Have you considered using the Mode 8 method?
Solax Mode 8 Modbus Power Control - Homeassistant SolaX modbus integration
R.
