Smart Switch or Relay
I have a 4 gang light switch in my kitchen which controllers different spotlights. Ideally I would like to make them smart and thought of replacing the bulbs but i know it wouldn’t stop the wife and kids turning the switches on/off. Any recommendations on light switches or a relay? Thanks
If you are going to install smart bulbs then then optimal option would be to use a relay behind the switch you currently have and set them up as decoupled so that power is constant and the physical switches only toggles the bulbs.
That said paul recently reviewed a new aqara light switch that does both physical power and scene setups:
