Smart Tag2 in Home Assistant
Hi!
I want to add the Smart Tag2 by using the Private BLE Device integration.
You need an IRK. I scanned using nRF Connect app and I can find and connect to the tag2, but can’t find the correct IRK. There are lots of numbers that look like a correct IRK and tried many, but all fail.
Has anyone succesfully added the Tag2 already?
Edit:
Buying a SmartThings Hub seems to be the best solution, because you can use the tag as device tracker in HA that way.
Please could you elaborate on how you managed to configure your tag as a tracked device in HA? I’ve added the smarthings integration but it only shows tag battery, volume and alarm entities?
I never got it working, sorry!
I found this HACS project https://github.com/Vedeneb/HA-SmartThings-Find but unfortunately the owner no longer maintains it :frowning:
The only fork I could see that might take on maintenance going forward is https://github.com/Sniptzler/HA-Samsung-Find
