I couldn’t find anything on here for this integration but my search skills have been lag as of late, and I don’t do discord. I’m not able to connect my ergomotion wifi bed controller to this app using the Wi-Fi credentials, or by using local ip. I’m not having luck with the instructions. The ui config does not save any info that I enter. The only way to get any of the information to actually save is to edit the yaml config.
The whole thing is confusing with ergomotion as they have several apps (ergomotion wellness, ergomotion 4.0, ergomotion sync, ergomotion, ergo slim, ergo wifi, ergo power command, and maybe even more?).
My particular bed uses the “ergo power command” app, which is supposedly for most all Wi-Fi models. I can control my bed using the epc app with no issue. I reserved the ip address of the controller in my router settings. The smart bed-mqtt integration/app/addon/thingamabobber will not connect direct via ip, or using the epc app creds. The log shows the following for local ip connection(where it just freezes at the last step):
“Using discovered MQTT Host: core-mosquitto
Using discovered MQTT Port: 1883
Using discovered MQTT User: addons
Using discovered MQTT password:
info [2026-03-17T01:32:33.263Z] [MQTT] Connecting…
info [2026-03-17T01:32:33.684Z] [MQTT] Connected
info [2026-03-17T01:32:33.685Z] [ErgoMotion] Setting up bed 192.168.xxx.xxx (address correct just deleted for post)”
When trying the cloud web creds, the log is as follows:
info [2026-03-17T01:40:40.982Z] [MQTT] Connecting…
info [2026-03-17T01:40:41.409Z] [MQTT] Connected
error [2026-03-17T01:40:42.058Z] AxiosError: Request failed with status code 404
error [2026-03-17T01:40:42.058Z] [ErgoWifi] Could not load devices for user (user is correct just deleted from post)”
From what I gather from git, it’s been a minute since anyone has checked in so I’m thinking the project has gone stale? Any tips on how to get this thing connected are appreciated. Even other app/addon/integrations that may work with an ergomotion wifi (not Bluetooth) smart bed.
