SmartIR climate / codes
I will appreciate if someone can help with SmartIR codes questions:
Does the temperature codes of the climate air condition should also include the “on” command? That means, when I learn, should I press the on button with the right temperature? or the temperature codes are just temperature, meaning, I learn only the temperature change, without on / off state.
If the temperature codes doesn’t include the on / off state, how does samrtir turns on the air condition?
I have electra air conditioner and the on / off is the same button, how does smartir handle it?
Thx
Its been a while and no one has posted, did you find the solution? I’m in the same predicament.
Only 6 years have passed since this message! Were you able to solve it? I have an Electra air conditioner made in Argentina and I can’t get it to work with a Broadlink Mini 4 and SmartIR.
