Thanks for the hints, I will continue to work on that project as soon as time allows and eventually report back.
A while back someone here asked about supporting the Maxxfan in Smart IR. I donât know whether that happened but hereâs some information you might find useful if youâre still looking for a solution.
I reverse engineered the Maxxfan infrared remote protocol and implemented a component to parse it. I havenât implemented the transmitter portion yet but itâs straightforward if folks want it.
Bonjour,
Je possĂšde une commande infrarouge Tuya modĂšle iH-F8260. ModĂšle Zigbee TS1201.
Jâai bien rĂ©ussi Ă installer SmartIR via HACS.
Ma télécommande est bien reconnu sur zigbee2mqtt.
Quand je demande dâapprendre un code, celui ci est bien appris et si je test, cela fonctionne correctement lors de lâenvoi de celui-ci.
Jâai donc créé un fichier JSON que jâai ajoutĂ© dans smartir/codes/climate.
Jâai ensuite rentrĂ© ma configuration dans configuration YAML
Jâai redĂ©marrĂ©
Et lĂ impossible dâavoir mon entitĂ© " climate " quand je veux crĂ©er une carte thermostat.
Jây est passĂ© des heures je dĂ©sespĂšre !
Merci par avanceâŠ
As promised an update: I managed to convert the codes from Broadlink to ESPhome, but it still does not work.
I tried to read and send IR codes with ESPhome directly with remote_receiver and remote_transmitter (without SmartIR). I managed to send commands to my daikin climate when I use âprontoâ, but it does not work with ârawâ.
I still have to dig into this, but as long as raw codes donât work, SmartIR cannot work since it is sending raw codes.
Any hints?
Do you see your climate in the entities-list? Make sure, that you really restart HA, and not only reload the configuration.
Bonjour, non il nâest pas visible dans les entitĂ©s quand je tape climate
I think it would significantly help, if you write in English. My French is not so good and others probably donât understand it at all.
I donât understand what exactly you mean with âtapeâ, so I cannot help you based on this comment.
No further hints necessary, in the end it was simple, just took quite some work to find it. I simply had to add the carrier frequency of 38.4 kHz.
services:
- service: send_raw_command
variables:
command: int[]
then:
- remote_transmitter.transmit_raw:
carrier_frequency: 38400.0
code: !lambda 'return command;'
Thanks for your support with the transformation tool.
Google Translate on their post:
Hello, no it is not visible in the entities when I type climate
Good morning,
Let me introduce myself, I am a bit new to the HA smartir and really want to know the possibilities because I think there are very great possibilities in this area with HA.
I donât speak English so thank you Google
I use Smartir with Broadlink RM4 for Fujitsu air conditioning with AR-RBE1E remote control.
I created my dashboard, entities, etc. and everything was fine except for one detail: turning on the air conditioning.
I can turn them off, change from cool to heat and dry but once turned off, even clicking on heat, dry and cool nothing happens.
has anyone ever had the problem? and where is the solution?
Otherwise I would like to add a power button but that is beyond my competence because I would have to program the .py file I think.
Thank you in advance for your help.
Did you learn the commands with the air-conditioner on?
What is now the best updated Version/fork
This or from litinoveweedle?
litinoveweedle. He keeps it up to date and supports more IR controllers.
Hello, i use the code of climate â1280,jsonâ and itâs not possible to start my clim.
I have testing with a learned code and itâs good.
I translate my learning code into 1280;json juste for used the climate interface and itâs good.
Thx the community
I created a dashboard to control my air conditioning using broadlinks but when I use automations, the information is not updated on the dashboard.
It is missing that the air conditioning is still on while the automation is off.
Anyone know how to use automation through the dashboard?
Thank you
Hello! Iâm new to this forum, Iâm trying to convert the Broadlink format to esphome with sircc.py, Iâm getting the errors below. Can you help me with some advice on how to convert the file? Thanks!
PS C:\Users\vali1> python3 sircc.py -i 2420.json -o 2420-converted.json -e Raw -c ESPHome
Convert commands.off
Ignored extra data: [13, 5]
Convert commands.cool.level1.16
Convert commands.cool.level1.17
Convert commands.cool.level1.18
Convert commands.cool.level1.19
Convert commands.cool.level1.20
Convert commands.cool.level1.21
Convert commands.cool.level1.22
Convert commands.cool.level1.23
Convert commands.cool.level1.24
Convert commands.cool.level1.25
Convert commands.cool.level1.26
Convert commands.cool.level1.27
Convert commands.cool.level1.28
Convert commands.cool.level1.29
Convert commands.cool.level1.30
Convert commands.cool.level1.31
Convert commands.cool.level1.32
Convert commands.cool.level2.16
Convert commands.cool.level2.17
Convert commands.cool.level2.18
Convert commands.cool.level2.19
Convert commands.cool.level2.20
Convert commands.cool.level2.21
Convert commands.cool.level2.22
Convert commands.cool.level2.23
Convert commands.cool.level2.24
Convert commands.cool.level2.25
Convert commands.cool.level2.26
Convert commands.cool.level2.27
Convert commands.cool.level2.28
Convert commands.cool.level2.29
Convert commands.cool.level2.30
Convert commands.cool.level2.31
Convert commands.cool.level2.32
Convert commands.cool.level3.16
Convert commands.cool.level3.17
Convert commands.cool.level3.18
Convert commands.cool.level3.19
Convert commands.cool.level3.20
Convert commands.cool.level3.21
Convert commands.cool.level3.22
Convert commands.cool.level3.23
Convert commands.cool.level3.24
Convert commands.cool.level3.25
Convert commands.cool.level3.26
Convert commands.cool.level3.27
Convert commands.cool.level3.28
Convert commands.cool.level3.29
Convert commands.cool.level3.30
Convert commands.cool.level3.31
Convert commands.cool.level3.32
Convert commands.cool.level4.16
Convert commands.cool.level4.17
Convert commands.cool.level4.18
Convert commands.cool.level4.19
Convert commands.cool.level4.20
Convert commands.cool.level4.21
Convert commands.cool.level4.22
Convert commands.cool.level4.23
Convert commands.cool.level4.24
Convert commands.cool.level4.25
Convert commands.cool.level4.26
Convert commands.cool.level4.27
Convert commands.cool.level4.28
Convert commands.cool.level4.29
Convert commands.cool.level4.30
Convert commands.cool.level4.31
Convert commands.cool.level4.32
Convert commands.heat.level1.16
Convert commands.heat.level1.17
Convert commands.heat.level1.18
Convert commands.heat.level1.19
Convert commands.heat.level1.20
Convert commands.heat.level1.21
Convert commands.heat.level1.22
Convert commands.heat.level1.23
Convert commands.heat.level1.24
Convert commands.heat.level1.25
Convert commands.heat.level1.26
Convert commands.heat.level1.27
Convert commands.heat.level1.28
Convert commands.heat.level1.29
Convert commands.heat.level1.30
Convert commands.heat.level1.31
Convert commands.heat.level1.32
Convert commands.heat.level2.16
Convert commands.heat.level2.17
Convert commands.heat.level2.18
Convert commands.heat.level2.19
Convert commands.heat.level2.20
Convert commands.heat.level2.21
Convert commands.heat.level2.22
Convert commands.heat.level2.23
Convert commands.heat.level2.24
Convert commands.heat.level2.25
Convert commands.heat.level2.26
Convert commands.heat.level2.27
Convert commands.heat.level2.28
Convert commands.heat.level2.29
Convert commands.heat.level2.30
Convert commands.heat.level2.31
Convert commands.heat.level2.32
File âC:\Users\vali1\sircc.pyâ, line 182, in
data[âcommandsâ] = convert_dict(data[âcommandsâ])
File âC:\Users\vali1\sircc.pyâ, line 178, in convert_dict
dic[key] = convert_dict(value)
File âC:\Users\vali1\sircc.pyâ, line 176, in convert_dict
dic[key] = convert(value)
File âC:\Users\vali1\sircc.pyâ, line 167, in convert
return convert_from_raw(convert_to_raw(command))
File âC:\Users\vali1\sircc.pyâ, line 157, in convert_to_raw
b = broadlink_len_fix(base64.b64decode(command.encode()))
File âC:\Users\vali1\sircc.pyâ, line 141, in broadlink_len_fix
assert data[0] == 0x26 # IR
IndexError: index out of range
I donât know much about Python, but what version of Python are you using, and what Broadlink JSON file are you converting? Perhaps your python version is too new or your using a Broadlink file that is too different. I havenât tried the converter on the forked version of SmartIR. You could try with some different files.
- Detected that custom integration âsmartirâ calls
async_track_state_change
instead ofasync_track_state_change_event
which is deprecated and will be removed in Home Assistant 2025.5 at custom_components/smartir/climate.py, line 176: async_track_state_change(self.hass, self._temperature_sensor,. Please report it to the author of the âsmartirâ custom integration - Detected that custom integration âsmartirâ calls
which is deprecated and will be removed in Home Assistant 2025.5 at custom_components/smartir/climate.py, line 184: async_track_state_change(self.hass, self._humidity_sensor,. Please report it to the author of the âsmartirâ custom integration
Instead of just pasting logfile snippets without any further comments about the issue(s) you encounter you might also want to tell us which SmartIR version you have installed.
- smartHomeHub â SmartIR
or the forked version:
- litinoveweedle â SmartIR (which is 407 commits ahead of, 74 commits behind smartHomeHub/SmartIR:master).
Issue reports, possibly with logfile snippets like yours above go to the issue reporting pages at GitHub of the respective devs.
Hi - same issue here - I wonât bother posting the log snippet. Both repositories had their last update 3 months ago, I use the original.
By the look of it the dev on the fork is still actively monitoring issues, so I will have to consider changing over and seeing if the same warning appears. If it does Iâll log an issue on Github
