If you get SmartIR to learn all the codes from your physical remote you should be able to use SmartIR to control everything on your A/C, not just on/off. You will be able to control fan speed, temp etc.
When you configure that contact sensor as your binary sensor to tell SmartIR that the unit is on/off, SmartIR will update HA accordingly. No need for automations. That’s why the power sensor entity exists in SmartIR (your original question)
Am I right that there are no deadband features like this?
Basically my target temp would be say 20 degree’s but I wouldn’t want my climate controller to kick in until around 18 or 22.
climate: #--------------------------------------------------------------------------------------------------------------------------------------------------
# Air Con
- platform: smartir
name: Living Room Air Conditioner
unique_id: living_room_air_conditioner
device_code: 1021
controller_data: remote.broadlink_rm2_pro_plus_3_remote
temperature_sensor: sensor.air_con_temp_current
humidity_sensor: sensor.humidity_158d0001c1a551
power_sensor: binary_sensor.door_window_sensor_158d0001c0fe60
Edit: I found the answer to this. No. SmartIR doesn’t implement control logic. But actually in my case I realised that because I have an invertor the unit is supposed to be on even when close to target. I think… So deadband approach isn’t so relevant.
Has anyone used a broadlink to control mitsubishi msz ga71va?
If so can ou pease share your .jason file?
I’lll be looking to add ceiling fans to mine aswell
Thank you
I somehow cant get it to work, also not with Broadlink Manager, because it expects nonexistent Buttons, i have no Idea what to do, i tried Broadlink Manager and it also expects Temperature value buttons.
Those simply don’t exist on my Remote.
My Remote has Six Buttons: Power, Speed, Mode, Timer, Temp + and Temp -
All Commands are within HA, but i have no idea how to make the AC Smart~ish
I'm running into an issue getting my Wemos D1 Mini with Lolin IR shield configured using SmartIR. Currently I'm getting the following error:
[homeassistant.helpers.service] Referenced entities esphome.livingroom_send_raw_command are missing or not currently available
Note that in my Esphome configuration, the on/off button configuration is working sending raw codes, so I'm pretty confident that most of the configuration is fine and I just need to get SmartIR correct.
Earlier I tried setting controller_data: livingroom_send_raw_command but was getting this error:
error
custom_components.smartir.climate] not a valid value for dictionary value @ data['entity_id']
File "/config/custom_components/smartir/climate.py", line 380, in send_command
await self._controller.send(
self._commands[operation_mode][fan_mode][swing_mode][target_temperature])
File "/config/custom_components/smartir/controller.py", line 111, in send
await self.hass.services.async_call(
'remote', 'send_command', service_data)
File "/usr/src/homeassistant/homeassistant/core.py", line 2782, in async_call
processed_data: dict[str, Any] = handler.schema(service_data)
File "/usr/local/lib/python3.14/site-packages/voluptuous/validators.py", line 259, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.14/site-packages/voluptuous/validators.py", line 386, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/usr/local/lib/python3.14/site-packages/voluptuous/validators.py", line 382, in _exec
v = func(v)
File "/usr/local/lib/python3.14/site-packages/voluptuous/schema_builder.py", line 205, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.14/site-packages/voluptuous/schema_builder.py", line 779, in validate_callable
return schema(data)
Running HA in Docker v2026.4.3 with SmartIR setup through HACS
HA configuration.yaml:
configuration.yaml
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
smartir:
climate:
- platform: smartir
unique_id: lounge_ac
device_code: 1691
controller_data: esphome.livingroom_send_raw_command
Does anyone have a tip on how to configure the JSON code file to suit a simple heater which has a basic ‘on’, ‘off’, ‘up’ and ‘down’ remote? I’ve been trawling through the example codes but not found one like that yet.
So far I’ve come up with this as a basis but haven’t tested it yet.
I’m using SmartIR with a Broadlink RM4C Mini to control a Mitsubishi Heavy air conditioner (device code: 1680).
The integration is working correctly for the main functions:
HVAC modes: off, cool, heat, dry
Fan modes: low, med, high, auto
Temperature control: 18–30°C
IR commands are being sent successfully via Broadlink
However, I have an issue regarding airflow direction (swing / louver control):
Although the IR configuration (1680.json) appears to include airflow/swing-related commands, I cannot see or control swing/airflow direction from the Home Assistant UI. In the climate.ac entity state, I do not see any swing_mode or airflow direction attribute exposed. Only fan modes are available.
Is this project dead, or are there still help to find?
I have a Delonghi Pinguino PAC EX93, a nice little unit with an IR remote.
The IR blaster is a Broadlink RM4 pro.
I have learned the basic commands to the system, and with those the RM4 can control the AC, but of course, it has no idea on what is going on, completely stateless.
So I started looking in to what could be done, and I found the SmartIR, and it even has codes for Delonghi.
Unfortunately none of them works for this AC.
I have it configured like this:
Ok, darned, well I will have to stay with the very poor implementation of the on/off button etc where HA doesn’t know anything about the state
I already have the IR codes learnt, I was just hoping something brilliant had come around.
where it doesnt know the state on / off just put a door contact sensor on the louvers is the easest thing to do … louvers open and work sensor state will be on
