SmartIR device does not appear
I have set up ‘SmartIR’ according to the instructions as far as I can tell.
and my configuration.yaml file has:
zha:
  custom_quirks_path: quirks/
smartir:
climate:
  - platform: smartir
    unique_id: bedroom_hvac
    device_code: 1000
    controller_data: 90:39:5e:ff:fe:26:ab:aa
    temperature_sensor: sensor.bedroom_temperature_temperature
    humidity_sensor: sensor.bedroom_temperature_humidity
but nothing appears in ‘entities’ for this device. no ‘remote.’ or ‘bedroom’
What am I doing wrong?
How come you use a MAC address (Silicon Laboratories) for controller_data?
Look up the referring HA entity for controlling your HVAC unit (i.e. an IR blaster or a thermostat or whatever device you use to control that HVAC unit) and put the correct entity behind controller_data:.
Remember to restart HA after having made changes to configuration.yaml.
I did because I was following these instructions:
I tried
but that didn’t work either
How does the ZosungIRBlaster show up as an entity?
HA → Developer Tools → States
I.e. as for our broadlink remotes here it looks like:
using remote.broadlink_rm4c_9_server_room_ac_remote for controller_data
Um… its not there
What shows when typing remote. at “Filter entities”
Nothing there that’s relevant
That Mac-address you used for controller_data (90:39:5e:ff:fe:26:ab:aa) is probably the MAC-address of the coordinator. Thus this can not work correctly for SmartIR.
You must use the entity for that ZosungIRBlaster for configuring controller_data.
Go through your entities. Maybe it is there with a different naming. Else that blaster may not be compatible with zha (or some errors within the quirk).
I can’t find a name for it. If I go into Manage Zigbee device I can turn the AC on and off by pasting the code. How do I access it from the rest of HA or give it an name? Since I can do it within the “manage zigbee device” I should be able to do it elsewhere?
