Smartir - Problem with the temperature sensor
Hey i have problems to setting up a temperature sensor for Smartir.
My sensor:
  sensors:
    temperature_wohnzimmer:
      friendly_name: "Temperatur Wohnzimmer"
      value_template: "Temperatur: {{ state_attr('climate.wohnzimmer', 'current_temperature') | float }}"
      unit_of_measurement: '°C'
      device_class: temperature
The Error:
`Unable to update from temperature sensor: could not convert string to float: 'Temperatur: 22.4'`
custom_components/smartir/climate.py (ERROR)
I hope someone can help me with my problem :slight_smile:
Thank you in advance!
In my code i have:
    sensors:
      vacuum_state:
        value_template: 'Blixten: {{states.vacuum.blixten.attributes.status }}'
So, i don’t know i your order is incorrect or you are using " insted of just ’
BR
Thank you for your answer.
The sensor itself works, but i think the smartir component can’t work with this value.
