I have been trying to get my ST communicating with my HASS. I am running it with Docker on a Synology DS1515+. I am using CloudMQTT as my broker, and am running StJohnJohnson’s MQTT bridge as a Docker container on the Synology as well.
So I tried adding the ST arrival sensor to HASS with no luck. I can see it in the frontend but no data is showing. I tried both binary sensor and sensor configurations. I tried adding a WeMo switch as well, it didn’t even show up in the HASS frontend.
Here are some questions in addition to the obvious ones:
- I’m not even sure if my MQTT is working because I don’t know how to test the communication. Is there a way to test it?
- How do I refer to an ST device in Home Assistant? Do they have UIDs?
- The MQTT bridge config file is located at /usr/src/app/_config.yml instead of ~/config.yml. Is there something wrong?
MQTT Bridge settings (I have changed port number, username and password for protection):
mqtt:
# Specify your MQTT Broker's hostname or IP address here
host: mqtt://m10.cloudmqtt.com:port
# Preface for the topics $PREFACE/$DEVICE_NAME/$PROPERTY
preface: smartthings
# Suffix for the state topics $PREFACE/$DEVICE_NAME/$PROPERTY/$STATE_SUFFIX
# state_suffix: state
# Suffix for the command topics $PREFACE/$DEVICE_NAME/$PROPERTY/$COMMAND_SUFFIX
# command_suffix: cmd
# Other optional settings from https://www.npmjs.com/package/mqtt#mqttclientstreambuilder-options
username: username
password: password
# Port number to listen on
port: 8080
My MQTT Configuration under configuration.yaml:
mqtt: broker: m10.cloudmqtt.com port: !secret cloudmqtt_port client_id: !secret cloudmqtt_client_id keepalive: 60 username: !secret cloudmqtt_username password: !secret cloudmqtt_password
Relevant Sensor Configurations under configuration.yaml:
binary_sensor:
- platform: mqtt
name: "Binary Arrival Sensor Presence"
picture: https://pbs.twimg.com/profile_images/833435180282974208/yOBGupTn_400x400.jpg
state_topic: "smartthings/Arrival Sensor/presence"
command_topic: "smartthings/Arrival Sensor/presence"
retain: true
- platform: mqtt
name: "Arrival Sensor Presence"
retain: true
- platform: mqtt
name: "Arrival Sensor Battery"
icon: mdi:battery
state_topic: "smartthings/Arrival Sensor/battery"
command_topic: "smartthings/Arrival Sensor/battery"
unit: '%'
retain: true
Some screenshots:
