SmartThings - Climate device add problem
I thought the air conditioner was added to SmartThings.
My air conditioner can not be added.
My device: Samsung Multi WiFi Kit(Accessories for cassette air conditioner).
Model name : AIM-H03N
This model is similar to MIM-H03U
Please help me
What is your version of Home Assistant?
Does the Air Conditioner show up in SmartThings?
Home Assistant 0.88.2 was released yesterday. Here is one of the things they fixed.
The Samsung Air Conditioners are a different beast and not currently supported by the climate platform. There’s an open issue (enhancement) and we’ll target to have it out in v.90! https://github.com/home-assistant/home-assistant/issues/21460
Thanks for your answer but my issue is quite different.
My AC can not be found at “https://graph.api.smartthings.com/
It means I can not found my AC at SmartThings Classic APP
But, I can found my AC at SmartThings NEW APP
Here’s my ST New APP screenshot image
Device witrh red box is my AC(WiFi Kit) and when Click AC
it shows 5 device(I have 5 AC at my home)
My HA version is 0.88.2
My AC show up in SmartThings NEW APP but not in Classic APP
Im using AIM-H03N(similar with mim-h03 / mim-h03n)
I cant find out the way
server.py , actest.py show me nothing :frowning:
here is mine…
curl -XPOST -H “Content-Type: text/xml” -d “<?xml version=\"1.0\" encoding=\"utf-8\" ?><Request Type=“GetToken” />” --cert /home/pi/actest/cert.pem “https://192.168.1.148:8888/capability” --insecure
{“errorCode”:“1008”,“errorDescription”:“Token is not Valid”}
Received packet from (‘192.168.1.148’, 36044):
b’HTTP/1.1 200 OK
CACHE-CONTROL: max-age = 600
DATE: Sun, 03 Mar 2019 04:18:44 GMT
EXT:
SERVER: Linux SHP/1.0 Air_Conditioner/1.0 deviceSubType/System_Air_Conditioner modelID/AIM-H03N
ST: uuid:abcdefgh-ijkl-0000-0000-000000000000
USN: uuid:abcdefgh-ijkl-0000-0000-000000000000
Received packet from (‘192.168.1.148’, 49630):
b’HTTP/1.1 200 OK
EXT:
ST: urn:SmartHomeAlliance-org:device:Air_Conditioner:1
USN: uuid:abcdefgh-ijkl-0000-0000-000000000000::urn:SmartHomeAlliance-org:device:Air_Conditioner:1
openssl s_client -connect 192.168.1.148:8888
depth=3 C = KR, O = Samsung Electronics, CN = ROOTCA
verify error:num=19:self signed certificate in certificate chain
write:errno=0
Certificate chain
** 0 s:/C=KR/O=Samsung Electronics/CN=DA_SET/[email protected]**
** i:/C=KR/O=Samsung Electronics/CN=DeviceCA/[email protected]**
** 1 s:/C=KR/O=Samsung Electronics/CN=DeviceCA/[email protected]**
** i:/C=KR/O=Samsung Electronics/CN=CECA**
** 2 s:/C=KR/O=Samsung Electronics/CN=RemoteAccessCA(CE)**
** 3 s:/C=KR/O=Samsung Electronics/CN=CECA**
** i:/C=KR/O=Samsung Electronics/CN=ROOTCA**
** 4 s:/C=KR/O=Samsung Electronics/CN=ROOTCA**
Server certificate
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
subject=/C=KR/O=Samsung Electronics/CN=DA_SET/[email protected]
issuer=/C=KR/O=Samsung Electronics/CN=DeviceCA/[email protected]
No client certificate CA names sent
Client Certificate Types: RSA sign, DSA sign, ECDSA sign
SSL handshake has read 4383 bytes and written 386 bytes
Verification error: self signed certificate in certificate chain
New, SSLv3, Cipher is AES256-SHA
Server public key is 1024 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
** Protocol : TLSv1**
** Cipher : AES256-SHA**
** Session-ID:**
** Session-ID-ctx:**
** Master-Key: abc**
** PSK identity: None**
** PSK identity hint: None**
** SRP username: None**
** Start Time: 1551589926**
** Timeout : 7200 (sec)**
** Verify return code: 19 (self signed certificate in certificate chain)**
** Extended master secret: no**
I’m using AIM-H03N, too.
Maybe selling that model in Korea only.
I couldn’t connect directly and make it control separately.
Certification is correct and connect http protocol but can not get token via standard api.
If you have any more information, please reply.
hi. 안녕하세요
웹 상에 존재하는 모든 방법을 시도해보았지만 토큰을 못구해서 저는 포기를 했습니다
통신선 직결하여 패킷제어를 시도해볼까 하다가
아직 못해본상태인데
신제품인 AIM-H04N 이 출시되어서
다른 사용자의 피드백을 기다리는중입니다
H03N은 디바이스(와이파이키트)1개에 실내기는 진입해야 제어가 되는것과 다르게
AIM-H04N는 디바이스가 실내기별로 생성되어서 개별제어가 원활해보입니다만
확실하게 확인이 필요합니다
만약 개별제어가 된다면 저는 기변 예정입니다
안녕하세요
저도 웬만한 방법은 다 시도해 봤지만 아무것도 안되더군요
webCoRE로 컨트롤할 수있는 방법은 없을까싶어 ST 스마트앱으로 webCoRE도 설치해봤지만 일반적인 디바이스가 아니어서 조회 중에 에러가 나구요
라이브 로그로 보니 하나의 디바이스에 경로를 나누는 방식으로 컨트롤하더군요
그래도 그루비 소스 자체가 막혀있어서 device handler 작성은 좀 어려워보이구요
나중에 저도 기변 혹은 와이파이킷과 실외기 통신구간 패킷을 따서 아두이노로 제어하는 킷을 따로 만들어볼까 고민 중입니다
혹시 다른 정보가 입수되면 공유 부탁드립니다.
공식 센터 및 설치 지원에 문의한 결과 개별 디바이스를 ST에서 지원할 예정은 없다고 답변받았었습니다.
안녕하세요.
신형 와이파이키트를 설치하면 기기 개별로 제어가 가능합니다.
그런데 딜레이 문제가 있어서 신호 따는게 문제겠지만 통신제어가 더 좋아보이긴합니다.
