I am in the process of setting up a second Home Assistant server. Is it possible to have both servers access the same Smartthings account. I have one hub and one locations. As best I can figure one hub can’t belong to multiple locations and each HA installation has to have a different location. Is this correct and is there a way around this.
Thanks to the developer for providing this integration.
@krskrab Thanks very much for the feedback. I’ll give it a try. From the discussion around the removal utility I got the impression it would only send to one HA instance. Did you use the same PAT for each?
