Smartthings Hub v2 with hassbian
I have a problem. I follow the steps in this guide https://www.youtube.com/watch?v=lUsMVrs1ot0 . Everything is going well but after use the commands below
sudo systemctl restart mosquitto.service
pm2 restart smartthings-mqtt-bridge
sudo systemctl restart [email protected]
sudo reboot
HA web interface is not available.
In SSH after command
sudo systemctl start [email protected]
receives the message failed to start [email protected]: unit [email protected] not found
Also the pm2 smartthings-mqtt-bridge doesn’t automatically start after a reboot.
Anyone can help? My configuration is RPi3 with HA installed according to this guide https://www.home-assistant.io/docs/installation/hassbian/installation/
Home Assistant is installed in a virtual Python environment at /srv/homeassistant/
Home Assistant will be started as a service run by the user homeassistant
The configuration is located at /home/homeassistant/.homeassistant
I had some issue, I gave up with Hassbian and Home Assistant and went to Hass.io instead, never looked back.
However I did the following to get it started
$ sudo su -s /bin/bash homeassistant
$ source /srv/homeassistant/bin/activate
$ hass
Hope it helps
I wanted to go from Hassbian to Hass.io but I need to use Lirc. Unfortunately, Lirc is not available on Hass.io so I have to stay at Hassbian.
