I have the MQTT bridge setup and working correctly. I can add devices on the HASS side that exist on SmartThings and they talk just fine. Is it possible to do the reverse? That is, if a Z-Wave device was paired with HASS, can I add a virtual device on the SmartThings side to control it? I would like to do this to slowly transition to HASS without minimal interruptions.
I created a virtual switch and added it to the MQTT bridge on the SmartThings smartapp, but I cannot get it to communicate with the HASS device. Have tried a bunch of name and address combinations in SmartThings to match the names on the HASS side. Iām sure its something simple (assuming this works).
On that same note, is it possible to have HASS discover SmartThings devices over MQTT the same way pairing a new z wave device on HASS works where it just shows up as a working device?
Thanks.
