Smartthings MQTT - questions and configuration example request
Hi there,
I started yesterday with HA on a raspberry pi so please consider this as I am not yet fully familiar with the system which may be why I got a few questions on this…
I have integrated my Smartthings setup via MQTT and got a few working devices already:
Binary_sensors
Fibaro Motion sensors connected to ST (working)
sensors
Fibaro Motion sensors, LUX output (illuminnance) (working)
Fibaro Motion sensors, temperature output (not working)
  • I can see the topic but have no idea what sort of device to create to get this to work
lights
various Osram bulbs connected to ST (partially working)
  • its RGB lights but I can only get the white function to work along with a limited brightness setting - I did set the scale but it still pushes out values higher than the specified scale, I did specify 100 but I can see eg 132 being pushed on the bus)
power outlets
I cant seem to find any detail how to use these - does anyone have any device configuration examples I could use?
I got 2 types, the ST one and the AeonTec Smart Plug Gen5 - I can see a power exposed on both but the Aeontec also has the capability of consumption which I again cant see on the bus only a power topic
interestingly I have enabled discovery on the MQTT but I had to manually enable/configure everything on the bus so far - so not sure why discovery isnt working …
anyone who can help, steer me towards some integrations? would be highly appreciated as its a bit overwhelming from the start …
cheers
r4n
