Hi, sorry newbie here! I have a lot of Meross devices which are added to HA via SmartThings. Given the issues with ST at the moment I installed the Meross integration to start doing away with ST. However the Integration still is ST not Meross. How do I force HA to use the Meross integration and not the ST integration?
Now that you’ve added the devices using the meross integration. First update your automation task to use the meross integrated device and than disable the parity device in the smartthings integration.
