Smartwatch detection?
Hi everyone
I was trying to setup smartwatch detection but it only works (it sends out beacons) if it is not connected to a phone. Once connected, EPSHome cannot see it anymore. But surely is it is sending data to my phone, so should be detected?
I have a Garmin watch if it makes any difference
Yep beacon or low energy BLE are working with only one active connection ! But if you use the HA app en your android Phone it reports you BLE devices connected with your phone or not (I have a Xiaomi Mi-Band that is paired with Gadgetbridge on my phone) and I have all the time status in HA if my Miband is connected or not with my phone :wink:
Screenshot_20210619_122333
yeah, I have seen this sensor in the app… Have to think of the logic on how to use it
I have a Garmin too and have tried everything (not with ESPHome but room-assistant, shouldn’t make a difference), to get it working - no luck. You will find a number of posts in the Garmin forums asking for a beacon functionality, with not reply from any developers. From what I read, future watches might allow this, but only when an app is open on the watch.
As you mentioned, the only thing you can do to get it working is to turn off Bluetooth on your phone. ESPHome/room-assistant will only pick up the broadcasts sent by the watch and no communication between the watch and the phone. It annoys me too, as the watch is on me almost 24/7.
Sorry but pretty confused here by your explanation ! The Garmin thing is paired with phone and an app on it right ? If so you’ll be able to know through HA app installed on same phone when the Garmin thing is BT linked or not (pretty useful in fact to get an automatic alarm if you forget to put it back on your wrist after charging/shower…
the discussion is more of a beacon function. So that when you walk into a room you are more likely to have a watch on your hand that a phone. But since it’s paired to a phone it is not sending adverts out.
I saw a guy on another group that wears a “watch” with microchip on one hand and smartwatch on the other. I am not ready for this yet =)
The only working solution :sweat_smile:
My galaxy fit have same issue.
And not every itag work. Some turn off after a while…
For Tizen it seems there are some apps that could help
or this
I know this is an old post, but thinking this through. I am wondering if I can disconnect the bluetooth between my phone and Garmin using Tasker when at home, probably easiest just to turn off Bluetooth for me, but may not be an option if you use Bluetooth headphones or some other Bluetooth device.
Then my Garmin watch would be sending out Bluetooth BLE beacons, then maybe once an hour turn back on to sync or only when the Garmin connect app is started.
This would hopefully then allow room assistant or similar to detect which room the Garmin watch was in.
This is all just theory at the moment and not sure if this would pass the wife test if I applied this to her phone/watch. I can hear the swearing now that is hasn’t synced.
@stevenhorner I just tried disconnecting my Galaxy Watch 5 from the phone by disabling BT on the phone. Then I ran
sudo hcitool lescan
on my computer and the watch did show up as a BT Low Energy device.
@cbarreholm interesting, I’ve not had the time to try anything. Sounds promising, need to find time to this myself.
hi did you succeed in this?
I have a garmin watch too connected with a bluetooth phone.
I want roompresence as well and prefer to pair the watch instead of the phone, cause phone i sometimes leave it on sofa, but the watch is always with me.
I dont think i need bluetooth at homr, only when i’m in the car,
Still looking for a solution :slight_smile:
Is this topic dead?
Still interested here.
It cant be that the people here and me, are the only ones wanting to do this with a garmin watch.
I found this too, but this doesnt advertise, right?
https://apps.garmin.com/en-US/apps/9bcc8b66-8385-4afb-b93e-f69e01422284
Mine has been working quite well for the last few months with the following.
I have setup Tasker (Android) to turn off Bluetooth on my phone whenever it sees my home Wifi, it turns it back on when not connected to my Wifi. If I open Garmin Connect on my phone it turns Bluetooth back on and back off when it is exited, which allows me to sync any activities.
I generally don’t use headphones very much at home, but when I do I manually turn Bluetooth back on and off. I could probably automate the Bluetooth off if the headphone were no longer connected.
I haven’t implemented this on the wife’s phone as she does look at notifications on her Garmin watch when in the house, where as I have enjoyed not having them other than when outside when they are more useful.
This surprisingly worked better than I expected for me, very quickly identifying where I am in the house reliably. The only other way I’ve tried was to turn on Broadcast Heartrate on my watch which also then works but it keeps changing the display to the heartrate, this appeared to affect battery life too.
Cool will try yours. I do see that tasker is paid.
But i think this is doable with automate too.
Will try.
It doenst need priviliges?
I have a huawei phone and it pops up an extra, are you sure to turn on/off bluetooth?
ok i bought tasker too.
I added the wifi connected → bt off, and if exit wifi, bt on
It works but my huawei still gives a popup that tasker wants to change it… how can i get rid of that?
From memory there was an app you could download from tasker that got rid of the message. If you search for the message you are seeing you should find it.
If not reply here and I will see if I can find a link, it was a while ago.
Cant find it :frowning:
Found this
But no help there.
What brand of smartphone do you have?
I might get a new smartphone soon too, and maybe ill go and take oneplus , but i have to be sure, it will work for that too.
If you could find the app to get rid of the message, i can make it work until i’ll get a new phone. (samsung or oneplus)
Sorry for the delay just upgraded my phone to a Pixel 8a, previously was a Pixel 4a. I needed to find the app too, it’s Tasker Settings from here:
You have to install it via ADB for Android 14 or above, will be installing it on my Pixel 8a this week to get it working again.On my old 4a I didn’t need to use ADB so was much easier to install and get it working.
