SMLIGHT SLZB-06 doesn´t appear in Home Assistant Hardware
Hello everyone,
I’m trying to install the SMLIGHT SLZB-06 coordinator to create a Zigbee network, but this software doesn’t appear in Home Assistant so I can’t copy the address I need to add to MQTT2.
Just use google, plenty of info.
If you want to connect via network, you can to go to the web interface to get all the info. For going to the web interface you need the ip adress of the device which u get from your router.
Thanks mate. I´m tying :slight_smile:
