I am looking for a smoke detector, which I can silence for a certain duration through home assistant. Preferably I should be able to post the silence duration, or it should have a silence / unsilence api, so that I could unsilence it at the prefered time through the api.
Reason is, that I live in a studio appartement and would like to silence the smoke detector while cooking.
Zigbee or Wifi are both ok.
I have seen some devices with a silence command in the z2m device list and also a few mentions here about the Frient or Shelly smoke dector, but is not clear to what the silence command entails in each case.
The only types of silent alarms are those that will flash a visual queue instead of an siren that is designed for those that are deaf. You would be combining those with the z-wave adapter to bring them into HA for alerts this way for when it goes off.
edit to add to my reply for those in Australia this is AS 3786:2023:
Thank you for the reply, I live outside the US. Currently my appartement does not have a smoke detector at all, so I assume the rules are different here.
I am not sure if manufacturers modify their devices per country, but I assume since some devices have some silence functionality, it should still be possible?
They usually don’t. You’ll find most build one or two general units because fire code is generally the same world-wide now. (these rules have stayed pretty much the same since the '60s and every country has lawyers…)
You DONT want to do this. Please.
…Says the guy who has actually pulled people out of burned buildings.
So which is your recommendation for a studio appartement?
As I have mentioned at the moment my appartement does not have a smoke detector at all and if I install a regular one, I can imagine it going off multiple times per day, each time I cook something, boil water etc.
I saw some devices, like this one, that have this functionality:
but it doesn’t seem like the highest quality device, so I was hoping to a least find a good combination of both.
If your apartment does not have at least one smoke alarm in the home then its a highly dangerous situation and the landlord of the building will have to be taken to court about the matter to have it installed if other apartments as well do not have one and the only ones are in the common area but no where else.
My building has alarms in the common area at each level and each unit has one alarm installed powered by both a battery and mains just above our fire rated doors so in my case I would just be investing in the z-wave adapter to bring it into HA and have it properly installed for me or invest in a complementary alarm that is battery operated that integrates into HA out of the box.
Fires are the one thing that shoots my anxiety levels to the roof and past it so anything that breaks codes in this regard boils my blood.
OK, I did some research (I live in Switzerland) and it indeed looks like smoke detectors here are not obligatory by law, but recommended to the tenants to install. I am surprised by this difference in sentiment and appreciate your concerns, fire is not something to be taken lightly, therefore I decided to take a look in the first place.
Now regarding the question “smart or not smart one” I really don’t know. My wife is against installing one at all and I was hoping to find a compromise with the one I described. Now I am really not sure.
For reference these are the ones we have installed currently which have a replace by 2029 sticker on them and are checked out by our housing department when its time for testing:
and how its installed in the unit since I moved in:
So what is not clear to me is, how do these things behave with cooking, do they fire off each time there is some steam, or are they able in general to distinguish between smoke from fire and steam? What about smoke from burned oil during frying? These are the cooking methods we use in general.
Do you have these devices also installed in the kitchen in the US or just in other rooms?
I personally don’t cook since I just order my food in and at most I just use the microwave but my neighbor when he cooks if he does not open the door it can trigger it due to the sensitivity and the ones in the common area I have seen it take about a min for it to trigger when cooking smoke from burnt toast in a downstairs unit float up to my level.
It comes down to the placement and the type of device used, this is why if you read the PDF linked previous the recommendation for kitchens is to use heat based detection instead of particulate (this also goes for garages if you have similar particulate generation from tools when working on projects that may create a false trigger).
The alarm shown in my previous reply and its placement is the only one in my unit and is far from the kitchen but close to the front door and in my lounge room.
I have an airgradient one to help me monitor co2 and other particulate matter levels in the home via central placement so it’s that balance in my setup.
All that said the one gripe I have with the kitchens in our units is the lack of proper exhaust using the range hoods as all they do is cycle the air above the stoves… you have to actually have someone install a proper exhaust in our case when they are switched on to vent steam etc out the home properly hence the false triggers at times.
I have smoke, carbon monoxide (CO), and natural gas detectors.
The smoke detectors are placed in a central area on each floor (basement, 1st, & 2nd) and the garage. The CO detectors are placed very close to the source of combustion (basement furnace, basement hot water heater, and kitchen stove) and near the bedrooms on the second floor. The natural gas detectors are in the basement.
I cook almost every day and I have good ventilation when cooking. It is very rare (once per year maybe) for the smoke detector to trigger - this happens because I have accidently burnt something while cooking.
The CO detectors saved our lives when the furnace malfunctioned.
I would gladly have a false alarm rather than die.
Thank you for the detailed replies, my kitchen actually does have an exhaust that removes the air from the room, so it looks like in this case I might not get as many false alarms. Once per year is definitely acceptable, I was more worried about something like 2-3 times per day.
The heat sensor also sounds like a great idea.
In addition I almost forgot, that I already have a CO2 sensor in the room that I use for general ventilation reminders, so I could also use this to fire of an alarm if the CO2 level becomes abnormally high.
Generally if CO2 levels become high you will start feeling tired more and want to sleep which is also a leading reason for deaths esp in fires (more so with carbon monoxide exposure).
I used this graph as a baseline for my tracking and alerts in my setup:
alias: Air Quality Notifications
description: ""
triggers:
- type: carbon_dioxide
device_id: bab8294dc1791213bb0c8953d047c390
entity_id: a93bccf2642069b6f916aa9a3ff105e0
domain: sensor
trigger: device
above: 1099
below: 1598
for:
hours: 0
minutes: 1
seconds: 0
id: Mediocre Co2 Level
domain: sensor
trigger: device
above: 1599
below: 2100
for:
hours: 0
minutes: 1
seconds: 0
id: Bad Co2 Level
domain: sensor
trigger: device
below: 500
for:
hours: 0
minutes: 1
seconds: 0
id: Normal Co2 Level
conditions: []
actions:
- choose:
- conditions:
- condition: trigger
id:
- Mediocre Co2 Level
sequence:
- data:
message: Contaminated indoor air. Ventilation Reccomended.
title: AQI Mediocore Co2 Level
notification_icon: mdi:molecule-co2
color: yellow
action: notify.mobile_app_rkphone
- type: turn_on
device_id: 84f621331e03317db049531f9338d348
entity_id: 86aa87cc4b2796bc48d097a9f6055f5d
domain: fan
- action: fan.set_preset_mode
metadata: {}
preset_mode: sleep
- conditions:
id:
- Bad Co2 Level
sequence:
- data:
message: Heavily contaminated indoor air. Ventilation Required!
title: AQI Bad Co2 Level
color: red
- conditions:
id:
- Normal Co2 Level
sequence:
- type: turn_off
domain: fan
mode: single
Yeah, I have a similar setup, where I get reminded through the speakers to ventilate when the CO2 level is above 1500. But at the moment this function gets muted at night, to don’t wake me up Guess I need to add another unmutable alarm for a higher treshold.
But in any case, I think the CO2 sensor should only be an auxilliary measure for fire protection and I still have to look into the other 2 solutions.
