The volume is also dropping immediately on a HomePod mini speaker pair.
I think it worked initially, until I added a media_player.pause step after it in my test automation. Then it dropped the volume but didn’t stop the playback. I disabled the pause step and nowI just get an immediate volume drop. I have set the fade duration to 5s.
This is just what I was looking for.
With this script and if I can find/make the perfect sunrise simulation with mij hue lights it will make the perfect alarm clock.
Iam no testing it on mij HomePod mini, I let a song being played of my Roon Core for 20 min, but when the time is reached 17min I get the following error:
Stopped because of unknown reason “null” 3 maart 2023 om 16:33:43 (runtime: 1026.64 seconds)
does anybody else has this error and know how to fix it?
I really hope we can get a core feature in Home Assistant where it just works as a variable in the media_player service calls. Just like lights with transition variable, this would be great if media_players supported transition.
Would it be possible to have the automation stop itself it it detects a volume change that it did not call, this would be great for easily stoping the automation in the morning.
For those struggling with timing, we got sub-second resolution in automations & scripts in 0.113 but there still seem to be limitations. I’ve been testing on a 2018 Mac Mini (3 GHz 6-Core Intel Core i5)- which should have plenty of horsepower for this- and the fastest I can adjust Spotify’s volume is about every 350 msec. Maybe it’s an internet thing with the Spotify integration phoning home, I don’t know.
That’s still three changes per second though so if your performance is the same as mine and you get the delta right it should be smooth enough.
@fmon For whatever it’s worth, I shared a light-fader script that I had written the other day, and in that script I haven’t had any trouble updating lights as often as every ≈110 ms or so.
I’ve modified this script into a version that takes an input number helper to store the players current volume to save or restore the volume automatically. Script will only restore volume when turned down to prevent automations from fighting the user for volume changes and will only save volume when above zero.
I took the liberty to rewrite the script and base it on the time passed during the fade.
no more deviation based on how ‘fast’ the script runs - fades take as long as specified by caller.
duration now uses the duration selector type (HH:MM:SS format)
the time between fade steps can be adjusted from 10 - 2000ms to accomodate media players that do not like commands in rapid succession
Possibility to abort a fade by emitting a custom event media_player_fade_volume_abort with the matching target_player in the additional data.
The Updated Script
media_player_fade_volume:
alias: Fade the volume of a media player
mode: restart
fields:
target_player:
name: Target media player
description: Target media player of volume fade.
required: true
example: media_player.lounge_sonos
selector:
entity:
domain: media_player
target_volume:
description: Volume the media play will be at the end of the fade duration.
required: true
default: 0.5
example: "0.5"
selector:
number:
max: 1
min: 0
step: 0.01
mode: slider
duration:
description: Length of time the fade should take.
required: true
default:
hours: 00
minutes: 00
seconds: 05
selector:
duration:
curve:
name: Fade curve algorithm
description: Shape of the fade curve to apply.
required: true
default: logarithmic
example: logarithmic
selector:
select:
options:
- logarithmic
- bezier
- linear
fade_step_timeout:
name: "Time between volume steps in milliseconds. [Script Tuning]"
description: >-
Smaller value -> smoother fade steps (but could cause problems with some players interpreting this as bad behaviour).
Bigger value -> less events to media player (which could be needed in case media player is overwhelmed by rapid commands).
500ms (2 fade steps per second) is a good compromise - no audible steps and most players should handle the load fine.
required: true
default: 500
example: "500"
selector:
number:
max: 2000
min: 10
step: 10
mode: slider
unit_of_measurement: ms
variables:
start_volume: "{{ state_attr(target_player, 'volume_level') | float(0) }}"
start_timestamp: "{{ as_timestamp(now()) }}"
fade_volume_diff: "{{ (target_volume - start_volume) | float(0) }}"
fade_duration: "{{ duration.hours * 3600 + duration.minutes * 60 + duration.seconds }}"
fade_duration_cutoff: "{{ fade_duration - 0.2 }}"
sequence:
- alias: "Set the media player volume in incremental steps for the fade duration."
repeat:
sequence:
- alias: "Set next volume step. Value based on time progress of fade, start/end volume and algorithm."
service: media_player.volume_set
data_template:
entity_id: "{{ target_player }}"
volume_level: >-
{%- set relative_fade_pos = (as_timestamp(now()) - start_timestamp) / fade_duration %}
{%- if curve == 'logarithmic' %}
{{ (start_volume + (relative_fade_pos / (1 + (1 - relative_fade_pos))) * fade_volume_diff) | float(0) }}
{%- elif curve == 'bezier' %}
{{ (start_volume + (relative_fade_pos * relative_fade_pos * (3 - 2 * relative_fade_pos)) * fade_volume_diff) | float(0) }}
{%- else %}
{{ (start_volume + relative_fade_pos * fade_volume_diff) | float(0) }}
{%- endif %}
- alias: "Fade can be aborted by sending an event - wait for event before we continue with next fade step."
wait_for_trigger:
- alias: "'media_player_fade_volume_abort' event with matching target_player entity"
platform: event
event_type: "media_player_fade_volume_abort"
event_data:
target_player: "{{ target_player }}"
timeout:
milliseconds: "{{ fade_step_timeout }}"
- alias: "If abort event was received we stop script execution right away. Volume remains at current value."
if:
- alias: "Received the 'media_player_fade_volume_abort' event with target_player of current script instance."
condition: template
value_template: "{{ wait.trigger != none }}"
then:
- stop: "Script aborted by 'media_player_fade_volume_abort' event."
until:
- alias: "Time passed in fade is close to desired duration."
condition: template
value_template: "{{ (as_timestamp(now()) - start_timestamp) >= fade_duration_cutoff }}"
- alias: "Ensure media player is set to target volume after fade finished"
data_template:
volume_level: "{{ target_volume }}"
icon: mdi:tune-vertical
Media player has to be the same as the script is currently fading the volume on.
Parallelism
Currently the script restarts if started again which aborts the ongoing fade and starts the new one.
It would be cool to be able to run this script in parallel for multiple media players.
Currently I only have one player so no need for this use-case but it was the first thing I thought about when I had this finished
For this it would be needed to check
change mode to parallel
check before script starts fading the volume if script is already running for same media player
script stops itself if it is already running for the same media player
