Smoother upgrade without waiting
after doing pip install -U homeassistant home-assistant-frontend. a restart will upgrade all each integration and its dependencies which take a lot of time before starting everything.
suggestion: allow upgrade integration and its dependencies before restarting
current what I do is to script like:
hass -c /etc/homeassistant --script ensure_config (a few dependencies but everything, is upgraded)
hass -c /etc/homeassistant --script check_config (a few dependencies but everything, is upgraded)
hass -c /etc/homeassistant (upgrade everything, but it won’t exit)
sv restart homeassistant (never reach here)
suggestion: add hass -c /etc/homeassistant --upgrade. my upgrade script will now be:
A bit of advice…I’d share your FR using the correct format for the code
:one::one: Format it properly
When sharing the code, share it as text and not an image. When you do that, remember that spacing is critical in YAML, and if you just throw the code on the page then it’ll look ugly and nobody will know if the problem is because of spacing. We need you to use code blocks and appropriate markup.
You can also vote for your own FR
Are you running core? if so it is 99% self supported, and few people know what you are talking about.
More than half the the HA users just say yes when offered an up date.
