Howdy, running HA 0.51.2, I have the notify portion set up correctly (notify.smtp component loads correctly upon startup), and am able to successfully trigger an SMTP notification, but nothing actually gets sent. In the logs, I see the following, and then nothing else:
2017-08-22 14:28:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service=smtp_txt, service_call_id=1973478032-64, service_data=title=HA test title, message=HA test message, domain=notify>
2017-08-22 14:28:14 DEBUG (Thread-8) [homeassistant.components.notify.smtp] Building plain text email
2017-08-22 14:28:15 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1973478032-64>
Here’s what I’m doing: Domain: notify Service: smtp_txt Service Data: {"title": "HA test title", "message": "HA test message"}
Calling the notify.smtp_txt service from an automation yields the same results.
Thank you for that. I tested using swaks, and everything looks good: was able to receive my swaks test message. It seems like there’s something gummed up in Home Assistant. Going to try unleashing debug as default, instead of just for homeassistant.components.notify to see if anything stands out in the logs.
EDIT
Nothing much after:
2017-08-22 20:22:56 DEBUG (Thread-3) [homeassistant.components.notify.smtp] Building plain text email
- action:
- data:
message: 'This is just a test'
service: notify.smtp_txt
alias: Notification Test
condition: []
- entity_id: switch.tool_room__lights_switch
platform: state
to: 'on'
Negative. This automation was specifically created to trigger a notification. I’m going to rebuild my HA server (full-blown Ubuntu on a netbook, instead of Hassbian 1.3 on a RPi3b). Maybe I mucked something while installing AppDaemon or dev build of OpenZwave. It’s just strange that the logs show that it’s building the email, but then it just goes dark, and no email is actually sent/received.
Will report back after the rebuild. Thanks again for your help!
Stood up an Ubuntu 16.04 machine, installed HA 0.51.2, copied the contents of /home/homeassistant/.homeassistant/ from the old machine to the new. Notifications are working properly. Thanks again!
