Snapcast Web UI (Vue 3 + Tailwind)
A modern, responsive, and feature-rich web interface for Snapcast, built with Vue 3 and Tailwind CSS.
Preview
Features
- Clean and modern UI
- Fully responsive design
- Easy volume control
- Simple group management
- Lightweight and fast
Installation Options
You have two ways to use it:
1. Replace snapweb
- Use it as a direct replacement for the default Snapcast web interface.
2. Home Assistant (HAOS) Add-on
- Install it as an app (Add-On) in Home Assistant OS
- Configure your Snapcast server IP in the settings
Authentication
On first load, you’ll be prompted to set a password.
This is a temporary solution and may be removed in the future, especially when running inside Home Assistant.
Notes
This project aims to simplify Snapcast control, making volume and group management much more intuitive compared to the default interface.
