Snapshot error
My latest snapshot of Home Assistant 0.112.0 (Home Assistant Supervised) is missing the database and the log file is showing this error:
20-07-02 10:11:08 ERROR (MainThread) [supervisor.addons.addon] Can't write tarfile <supervisor.utils.tar.SecureTarFile object at 0x7fc7db8b1a10>: [Errno 13] Permission denied: '/data/addons/data/core_mariadb/databases/mariadb.err'
20-07-02 10:11:08 ERROR (MainThread) [supervisor.snapshots.snapshot] Can't make snapshot from core_mariadb
I’ve restarted both the database and home assistant but the error is still showing. It’s been a few weeks since my last backup (which included the DB), so I’m not sure if the problem relates to 0.112.0
Has anyone else experienced this and are there any suggestions for how to resolve this issue?
I am seeing the same issue now. Not sure how to solve at this point.
I noticed the same. The last backup that has the database backed up was 6 weeks ago. The recent backups did not. This was on a unsupported generic linux install.
I found out wile I was moving my Hass install to a supported install (Rpi4 w/ssd), to workout another problem with the unsupported install.
After I had my HassOS rpi4 running I made a few new backups and it’s backing up the DB fine now.
In my case I believe my install method was incompatible.
Try a partial back up and select everything It may work.
