Hi all, loving Home Assistant so far!
I have a generic chinese 8ch DVR with AHD cameras. Each camera is accesible on an RTSP stream (DVR encodes the analog camera, presents it as a stream I can use over IP)
rtsp://192.168.0.250:554/user=admin&password=privateeditedout&channel=1&stream=0.sdp
I ran a port scan against it and only RTSP (port 554) and HTTP (port 80) is open
I spent a lot of time looking for a still_image url from the DVR, but no luck. The webserver on port 80 only gives the ActiveX based “application” access - and in there is no static view either
Is there way to make Home Assistant grab a snapshot out of the RTSP stream?
Config:
stream:
camera:
- platform: generic
still_image_url: rtsp://192.168.0.250:554/user=admin&password=7szlyq&channel=1&stream=0.sdp
stream_source: rtsp://192.168.0.250:554/user=admin&password=7szlyq&channel=1&stream=0.sdp
Just testing the Snapshot from developer tools > Services > camera.snapshot> camera.cam1 with
entity_id: camera.cam1
filename: /config/www/snapshot.jpg
No errors in log, but also no snapshot
if I edit the config to use a jpg url from the internet for example, the same test saves the snapshot of that internet picture (whatever url, doesn’t matter, point is it seems to want a “still image” for the still image URL, if i give HA the RTSP url for still_image_url, nothing happens (kinda expected)
So how can I get a static image out of the RTSP stream?
