Snips Addon issue
I try to use the Snips Addon, but I get this error:
2018-03-01 14:10:13,242 INFO exited: snips-audio-server (exit status 1; not expected)
2018-03-01 14:10:16,253 INFO spawned: 'snips-audio-server' with pid 107
INFO:hermes_mqtt: Connecting to MQTT broker at address localhost:1883
1519909816: New connection from 127.0.0.1 on port 1883.
1519909816: New client connected from 127.0.0.1 as mqttc_217377068 (c1, k5).
INFO:rumqtt::connection: $$$ Connected to broker
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
thread '<unnamed>' panicked at 'called `Option::unwrap()` on a `None` value', /checkout/src/libcore/option.rs:335:20
note: Run with `RUST_BACKTRACE=1` for a backtrace.
Error: Error in audio driver
1519909816: Socket error on client mqttc_217377068, disconnecting.
2018-03-01 14:10:16,520 INFO exited: snips-audio-server (exit status 1; not expected)
2018-03-01 14:10:17,523 INFO gave up: snips-audio-server entered FATAL state, too many start retries too quickly
I’m not really sure how to fix it. The assistant.zip is in the /share/ folder and my config looks like this:
  "mqtt_bridge": {
    "active": false,
    "host": "core-mosquitto",
    "port": 1883,
    "user": "",
    "password": ""
  "mic": "0,0",
  "speaker": "0,0",
  "assistant": "assistant.zip"
(I want to use the built-in headset port for mic and speaker with my headphone)
Any idea what the issue could be?
I have your same problem
