SNMP Error
So i enabled SNMP on my Advanced Tomato router, then i used Getif to verify that its up and running, i also tried to query my connected devices with oid .1.3.6.1.2.1.4.22.1.2 and it worked.
So i added the following to my configuration
device_tracker:
  - platform: snmp
    host: 192.168.0.1
    community: readonly
    baseoid: .1.3.6.1.2.1.4.22.1.2
i also tried without the initial dot on the baseoid.
But when starting home assistant i get the following error
17-03-11 11:11:53 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform snmp
  File "C:\Users\xbmc\AppData\Local\Programs\Python\Python36-32\lib\site-packages\homeassistant\components\device_tracker\__init__.py", line 165, in async_setup_platform
    None, platform.get_scanner, hass, {DOMAIN: p_config})
  File "C:\Users\xbmc\AppData\Local\Programs\Python\Python36-32\lib\concurrent\futures\thread.py", line 55, in run
  File "C:\Users\xbmc\AppData\Local\Programs\Python\Python36-32\lib\site-packages\homeassistant\components\device_tracker\snmp.py", line 45, in get_scanner
    scanner = SnmpScanner(config[DOMAIN])
  File "C:\Users\xbmc\AppData\Local\Programs\Python\Python36-32\lib\site-packages\homeassistant\components\device_tracker\snmp.py", line 77, in __init__
    data = self.get_snmp_data()
  File "C:\Users\xbmc\AppData\Local\Programs\Python\Python36-32\lib\site-packages\homeassistant\components\device_tracker\snmp.py", line 115, in get_snmp_data
    self.auth, self.host, self.baseoid)
  File "C:\Users\xbmc\AppData\Roaming\.homeassistant\deps\pysnmp\entity\rfc3413\oneliner\cmdgen.py", line 221, in nextCmd
    **kwargs):
  File "C:\Users\xbmc\AppData\Roaming\.homeassistant\deps\pysnmp\hlapi\asyncore\sync\cmdgen.py", line 355, in nextCmd
    lookupMib=options.get('lookupMib', True)))
  File "C:\Users\xbmc\AppData\Roaming\.homeassistant\deps\pysnmp\hlapi\asyncore\cmdgen.py", line 352, in nextCmd
    options.get('cbFun'), options.get('cbCtx'))
  File "C:\Users\xbmc\AppData\Roaming\.homeassistant\deps\pysnmp\entity\rfc3413\cmdgen.py", line 258, in sendVarBinds
    v2c.apiPDU.setVarBinds(reqPDU, varBinds)
  File "C:\Users\xbmc\AppData\Roaming\.homeassistant\deps\pysnmp\proto\api\v1.py", line 136, in setVarBinds
    varBindList.getComponentByPosition(idx), varBind
  File "C:\Users\xbmc\AppData\Roaming\.homeassistant\deps\pysnmp\proto\api\v1.py", line 43, in setOIDVal
    verifyConstraints=False)
TypeError: setComponentByType() got multiple values for argument 'verifyConstraints'
I ran check_config and it gave me no errors so what am i missing?
Python: 3.6.0
Home Assistant: 0.39.3
It seems like this is a known problem python 2.7 - PYSNMP : TypeError: setComponentByType() got multiple values for keyword argument 'verifyConstraints' - Stack Overflow
Version 0.40.0 fixed this issue!
