SNMP issue. HA complains about no yaml config, but integration says yaml only?
I try to get the status of my HP DesignJet 500
(its housed in my shed, want to know when its finished printing)
I was successful in getting my state by command line
PS C:\Users\ManneBK> Get-SnmpData -IP "10.101.111.126" -OID ".1.3.6.1.4.1.11.2.3.9.1.1.2.10.0" -Community "public"
Data OID
1    .1.3.6.1.4.1.11.2.3.9.1.1.2.10.0
so i created a SNMP entry for the config yaml in HA
snmp:
  - sensor:
      - host: 10.101.111.126
        baseoid: "1.3.6.1.4.1.11.2.3.9.1.1.2.10.0"
        name: "DesignJet 500 Status Rohwert"
        community: "public"
        version: "2c"
        scan_interval: 60
result is “configuration doesn’t prevent HA start”
and
Die snmp-Integration unterstĂĽtzt keine YAML-Konfiguration
Fehler · Von Home Assistant Core Integration gemeldet
Die snmp-Integration unterstützt keine Konfiguration über eine YAML-Datei. Möglicherweise bemerkt man bei der Integration keine offensichtlichen Probleme, aber die in YAML definierten Konfigurationseinstellungen werden nicht tatsächlich angewendet.
Um dieses Problem zu beheben:
    Falls du dies noch nicht getan hast, richte die Integration ein.
    Entferne snmp aus deiner YAML-Konfigurationsdatei.
    Starte Home Assistant neu.
and if i follow the given link (that presumably would add the SNMP integration via UI), it tells me the link doesnt exist and askes if i have the newest HA, i do.
If i try adding SNMP via GUI, it complains about only accepting yaml configuration.
thereby clearly contradicting itself.
So what am I doing wrong here?
Did you restart HA after changing configuration.yaml?
Also your config does not look like anything in the docs
snmp:
  - sensor:
        community: "public"
        version: "2c"
        scan_interval: 60
might have to be more like
  - platform: snmp
    community: "public"
    version: "2c"
    scan_interval: 60
yes i did, i even rebooted the machine.
and your recommendation for config was my first try, HA did see nothing, nothing… (Schulz)
So i plugged it into google and chat and got the second version, that at least did result in some reaction by HA…
… thanks to your hint, well, I think i figured it out.
i added my first stuff to the templates.yaml under “sensors:” cause i had it with sensor:… dumb
now add it as sensors: to my config yaml and who would have guessed, it works.
thanks man, you got me on the right track.
Good to hear, I should have guessed that you might have had it buried in template: when I saw the dash in front of the sensor: as I knew that was wrong.
