SNMP Scan interval
Is there a way configure scan interval ?
my code:
  - platform: snmp
    host: 192.168.0.111
    baseoid: 1.3.6.1.2.1.1.3.0
  - platform: snmp
    name: Mini PC Uptime
    host: 192.168.0.122
    baseoid: 1.3.6.1.2.1.25.1.1.0
i didn’t saw any scan interval option in the topic: https://www.home-assistant.io/integrations/snmp/
I don’t mean to hijack the thread, but I’ve got a quick question about the scan_interval option:
Should scan_interval work on every integration that does polling in HA?
Yes, it should.
Thanks, I was using the ‘twitch’ integration here - in says in the top-right: IoT class: Cloud Polling:
And I found that even with scan_interval set to 1 min in my YAML, the integration would still access the API over 5 times per second.
Is this a bug? If so would it help to make a github issue for this?
Could be that’s a bug. Yes, please open an issue on GitHub. Thanks.
