SNMP Sensors won't parse oid entry?
I am trying to read an Axe Effect sensor in my very basic HA config using the standard ENTITY-SENSOR-MIB and should return an integer type. This is my configuration.yaml:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
  - platform: google_wifi
    host: 192.168.0.1
    monitored_conditions:
      - current_version
      - new_version
      - uptime
      - last_restart
      - local_ip
      - status
  - platform: snmp
    host: 192.168.0.80
    version: '1'
    community: 'public'
    baseoid: 1.3.6.1.2.1.99.1.1.1.4.0
    unit_of_measurement: 'Deg F'
# Conversion from C to F is (Degrees C *  9/5) + 32 = Degrees F
# Axe Effect reports in integer 1/100ths of a degree F so devide number fetched by 100 ro correct the decimal point
    value_template: '{{ ((value * 9 / 5 ) + 32 ) }}'
The error I am getting is one that doesn’t make sense to me. The only error thrown right away after re-reading the yaml files is:
SNMP error for OID .1.3.6.1.2.1: No Such Object currently exists at this OID
If I snmpget that OID object from the config file I get
neil@Dell3910:~$ snmpget -v 1 -c public 192.168.0.80 1.3.6.1.2.1.99.1.1.1.4.0
iso.3.6.1.2.1.99.1.1.1.4.0 = INTEGER: 2328
If I snmpwalk the entire entitySensorMIB I get this:
neil@Dell3910:~$ snmpwalk -v 1 -c public 192.168.0.80 1.3.6.1.2.1.99
iso.3.6.1.2.1.99.1.1.1.1.0 = INTEGER: 8
iso.3.6.1.2.1.99.1.1.1.2.0 = INTEGER: 9
iso.3.6.1.2.1.99.1.1.1.3.0 = INTEGER: 2
iso.3.6.1.2.1.99.1.1.1.4.0 = INTEGER: 2327
iso.3.6.1.2.1.99.1.1.1.5.0 = INTEGER: 1
iso.3.6.1.2.1.99.1.1.1.6.0 = STRING: "deg C"
iso.3.6.1.2.1.99.1.1.1.7.0 = INTEGER: 157017
iso.3.6.1.2.1.99.1.1.1.8.0 = INTEGER: 5011
iso.3.6.1.2.1.99.1.1.2.1.0 = INTEGER: 1
iso.3.6.1.2.1.99.1.1.2.2.0 = INTEGER: 9
iso.3.6.1.2.1.99.1.1.2.3.0 = INTEGER: 3
iso.3.6.1.2.1.99.1.1.2.4.0 = INTEGER: 46086
iso.3.6.1.2.1.99.1.1.2.5.0 = INTEGER: 1
iso.3.6.1.2.1.99.1.1.2.6.0 = STRING: "% RH"
iso.3.6.1.2.1.99.1.1.2.7.0 = INTEGER: 157017
iso.3.6.1.2.1.99.1.1.2.8.0 = INTEGER: 5011
Clearly the OID is there and can be access from my WSL instance on my Windows 11 PC, but HA is not reading something right. Any trhoughts?
SNMP need the exact leaf OID.
Branch OIDs will not work.
Other tools can extrapolate the leaf OID from the branch OID, if there is only one branch OID on each step to the leaf OID.
Thanks for responding so quickly. I am not sure what you mean. The 192.168.0.80 1.3.6.1.2.1.99.1.1.1.4.0 is the leaf OID (instance 0) from what I read in the MIB (though I am willing to be corrected). 1.3.6.1.2.1.99.1.1.1.4 is the entPhySensorValue final branch OID (at least as far as I read the entitySensorMIB. If I am not reading it right, can you point out what I should be putting for the OID? Sorry to be so dense, but I really find this confusing.
Instance 0 is just a number as the other numbers in the address.
There might be an extra 0 or 1 or so to get the leaf, if the 0 is still a branch.
Wouldn’t the SNMPwalk have noted that since it walks the tree to the leaves, then back-traces? The instance number at the end is a individual sensor measurement value. You can see that in the SNMPget I included. The numbers in the ASN.1 syntax aren’t “just arbitrary numbers”. They are structured ‘addresses’ that map back to the structure defined in the MIB (and inspection shows there are no further branch nodes out further in the MIB on that .4 branch, just sensor instance leaves).
I know that it is structured ‘addresses’, but it does not map back to the MIB.
The MIB maps the part of the SNMP structure that it have information about in a human readable form.
The SNMP structure works fine without the MIB, al though it can be hard to read for us humans.
I do not remember how snmpget and snmpwalk output its values, but it is the last leaf/branch that always trips this up, since HA is very strict with that structured ‘address’.
Try to remove the last .0 to see if that is the issue.
I personally use a Windows SNMP browser from iReasoning to do the SNMP looks up.
According to this: GitHub - CraftComputing/ProjectAxeEffect the correct OID for temperature is: 1.3.6.1.2.1.99.1.1.1.4.0
So I’m not sure why it is not working. If you work it out your config would need a bit of a tweak to get the value correct:
value_template: '{{ (9 * value / 500 ) + 32 }}'
Also the correct unit for Fahrenheit is '°F' not 'Deg F'
Have you tried
version: '2c'
That is also supposed to be supported.
I appreciate the correction to the value_template. I applied that with no problem, but it didn’t change anything of note. The change to the unit_of_measurement created a problem where HA would not start afterward. I seem unable to get that degree character in there. It always seems to be replaced by a dot. I finally ssh’ed in from another host to make sure it wasn’t just the HA web gui, and adding it from there appeared to place a unicode character in there. HA would restart in recovery mode until I removed that character. I removed it and got it to come back by deleting that one character. I finally used the windows Charmap app to get the seemingly correct one in, and HA at least starts. The error block I get now is:
Logger: homeassistant.helpers.entity
Source: helpers/entity.py:960
First occurred: 9:32:40 AM (2 occurrences)
Last logged: 9:32:50 AM
Update for sensor.axeeffect_temp fails
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 960, in async_update_ha_state
    await self.async_device_update()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1318, in async_device_update
    await self.async_update()
  File "/usr/src/homeassistant/homeassistant/components/snmp/sensor.py", line 214, in async_update
    value = self._value_template.async_render_with_possible_json_value(
        value, STATE_UNKNOWN
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 817, in async_render_with_possible_json_value
    render_result = _render_with_context(
        self.template, compiled, **variables
    ).strip()
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2904, in _render_with_context
    return template.render(**kwargs)
  File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 1295, in render
    self.environment.handle_exception()
  File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 942, in handle_exception
    raise rewrite_traceback_stack(source=source)
  File "<template>", line 1, in top-level template code
TypeError: unsupported operand type(s) for /: 'str' and 'int'
If you need the config again, it is:
default_config:
frontend:
    host: 192.168.0.1
      - current_version
      - new_version
      - uptime
      - last_restart
      - local_ip
      - status
  - platform: snmp
    host: 192.168.0.80
    version: '2c'
    community: 'public'
    unit_of_measurement: '°F'
    value_template: '{{ ( 9 * value / 500 ) + 32 }}'
Thanks for the help.
I did and it is set to that now, but I know the sensor supports version 1 of SNMP. That doesn’t seem to have affected things.
Could you change value in that value_template to (value | float)
And version 2c support 64bit counter, where version 1 only support 32.
It might not matter with the temperature, but with counters it might.
After changing, it still fails. The error message appears to be the same:
First occurred: 9:32:40 AM (952 occurrences)
Last logged: 12:11:11 PM
    ).strip()
That last line of the error implies that value is an INT instead of a floating point. Does the code cast it to an INT regardless of the type it was received as?
I restarted the whole HA instance and now it is working. I think it was the ( value | float ) change that got the data to display and the errrors to finally quit, but since I didn’t do a complete restart until this change, I am not positive. The final working configuration.yaml is:
default_config:
frontend:
    host: 192.168.0.1
      - current_version
      - new_version
      - uptime
      - last_restart
      - local_ip
      - status
  - platform: snmp
    host: 192.168.0.80
    version: '2c'
    community: 'public'
    value_template: '{{ ( 9 * ( value | float ) / 500 ) + 32 }}'
Thanks for all of the help.
Everything in HA is stored as strings, so casts to int or float is often a requirement, but maybe your value is not even a number.
Try to remove the value_template for now and just get the raw result.
I commented out the value template line and it just reported that my office was 2210 degrees C, but it didn’t error out. I have discovered that to really see the change here you have to restart the HA instance, not just re-read the yaml files.
That might be one of those integrations that needs a complete reload.
I switched to Node Red for handling my SNMP, since I had to do some advanced calculations that was not easily done in HA.
My final working config to get both the temp and relative humidity sensors reading and displaying in degrees F, this was what was required.
default_config:
frontend:
    host: 192.168.0.1
      - current_version
      - new_version
      - uptime
      - last_restart
      - local_ip
      - status
  - platform: snmp
    host: 192.168.0.80
    version: '2c'
    community: 'public'
  - platform: snmp
    host: 192.168.0.80
    version: '2c'
    community: 'public'
    baseoid: 1.3.6.1.2.1.99.1.1.1.8.0
    unit_of_measurement: '% RH'
    value_template: '{{ ( ( value | float ) / 100 ) }}'
As far as I understand it the value variable is typed (i.e. it is not always a string) however it depends on how your data is presented to the variable, e.g. ‘25’ will show as a string, 25 will be a number.
Though this tends to suggest otherwise:
So maybe that is just for the value_json variable.
The failure to restart was definitely an issue. You must restart Home Assistant after you use any integration for the first time in YAML. If the integration supports a unique id and you give it one then any subsequent additions of that integration can be loaded with just a yaml reload.
value is always a string, value_json is typed. I just went through that code this release.
Thanks for the clarification.
