Hi, I’ve read the docs and various posts but everything I try doesn’t work. I can install the SNMP tools from CLI and then SNMP command works fine to the switch (enable/disable a port) but from the switch config in configuration.yaml the switch just reverts to it’s previous state with nothing in the logs ?
I’m relatively new to HA, but used it for a while, just new to heavy custom things in it.
What am I doing wrong, it’s driving me nuts. Below is my YAML
I’m kinda rusty on SNMP (and I have only used sensors for my cases) but when I go down the oid tree, the oid you are using seems to be:
ifAdminStatus OBJECT-TYPE
SYNTAX INTEGER {
up(1), -- ready to pass packets
down(2),
testing(3) -- in some test mode
ACCESS read-write
STATUS mandatory
DESCRIPTION
"The desired state of the interface. The
testing(3) state indicates that no operational
packets can be passed."
::= { ifEntry 7 }
So about the only thing that looks a tiny bit off is the “down”/“off” value of 2 instead of 0.
If that doesn’t help, then the only other possible thing I see is there is a config parameter for vartype, so maybe set it to INTEGER?
