SNZB-02 vs SNZB-02P
this is not so much a quesion as some measures I want to share with you.
I put the SNZB-02 and the SNZB-02P next to each-other,both brand new, and let them measure for 2 days. (TH01 = SNZB-02)
What I notice here is that the temp is 0.3C lower on the P model, and the humidity 5%.
I don’t know which one is more acurate, but if you take a look at escpecially the humidity you see the graph being more smooth.
I assume this is because of the way it measures. It probably takes an AVG over the last couple of minutes instead of only the current value. This prevents spikes.
for humidity I think the P model is more accurate as over the whole year the none-P model gave me unrealistic high values.
The magnetic backplate of the P model makes it easier to replace the battery, disadvantage is that the orange color is ugly and one could easily just swap the sensors to prank you.
the identify button works only on the P model and according to the specs the battery life time is better.
this info is just so if anyone else is wondering what model suits you better.
For a comparison here is my SNZB-02P that is mounted in my bedroom vs the Airgradient one in the living room, there is no door between them and its a small place:
