So, my fan speed controller is not honoring the temp reading and speeding up the fan
I am sure that I am doing something wrong, but it just has not dawned on me yet. I am trying to set my fan speed based on the sht31 temperature reading. I removed the conversion to degrees F assuming that was the issue and it is not. This fan is intended to never turn off during operation. The setpoint should have the fan running at full speed, instead it is running at the minimum speed designated and I never see a log entry indicating it should change speed. I know I am doing something very simple wrong.
substitutions:
  friendly_name: Apple Fan Controller
  devicename: apple-fan
  esphome_platform: esp32
  esphome_board: esp32dev
  esphome_project_name: "Apple.temperature_control"
  esphome_project_version: "apple-fan-v.1"
esphome:
  name_add_mac_suffix: false
  project:
    version: $esphome_project_version
  on_boot:
# Power up fan at boot
    priority: 800
    then:
      - if:
          condition:
            api.connected: null
          then:
            - logger.log: API is connected! Now we can trigger what we want!
          else:
            - delay: 1s
            - output.set_level:
                level: 0.25 # 25% pwm speed until temp is taken
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  reboot_timeout: 0s
# Allow Over-The-Air updates
ota:
- platform: esphome
wifi:
  domain: .home
  ssid: !secret wifi_ssid
  # Set up a wifi access point
  ap:
    ssid: "${friendly_name}"
    password: "12345678"
dashboard_import:
  package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
  import_full_config: true
web_server:
  include_internal: True
status_led:
  pin:
     number: GPIO2
     inverted: false
i2c:
  sda: GPIO21
  scl: GPIO22
  frequency: 100kHz
output:
  - platform: ledc
    pin: GPIO27
    frequency: 25000Hz
number:
    name: "Pwm Fan Slider"
    min_value: 15
    max_value: 100
    step: 1
    optimistic: true
    set_action:
      then:
        - output.set_level:
            level: !lambda "return x/100;"
text_sensor:
  # Send IP Address
  - platform: wifi_info
    ip_address:
      name: $friendly_name IP Address
  # Send Uptime in raw seconds
    icon: mdi:clock-start
  - platform: sht3xd
    temperature:
      name: "Apple Internal Temperature"
      internal: false
#     filters:
#        - lambda: return x * (9.0/5.0) + 32.0;
      unit_of_measurement: "°F"
      on_value_range:
      - above: 20.0
        then:
          - logger.log: "Set fan level 100 over 20"
          - output.set_level:
              level: 100%
      - above: 18.0
        then:
          - logger.log: "Set fan level 66 over 18"
          - output.set_level:
              level: 66%
      - above: 17.0
        then:
          - logger.log: "Set fan level 33 over 17F"
          - output.set_level:
                level: 33%
      - below: 17.0
        then:
          - logger.log: "Set fan level 0 under 17F"
          - output.set_level:
                level: 15%
    humidity:
      name: "Apple Internal Humidity"
      internal: false
    address: 0x44
    update_interval: 30s
  # Fan Speed
  - platform: pulse_counter
    pin:
      number: GPIO25
      mode:
        input: true
        pullup: true
    name: PWM Fan RPM
    unit_of_measurement: 'RPM'
    internal: false
    filters:
      - multiply: 0.5
    count_mode:
      rising_edge: INCREMENT
      falling_edge: DISABLE
    update_interval: 3s
   # Send WiFi signal strength & uptime to HA
  - platform: wifi_signal
    name: $friendly_name WiFi Strength
    update_interval: 60s
  - platform: uptime
    name: $friendly_name Uptime Human
    on_raw_value:
      then:
        - text_sensor.template.publish:
            # Custom C++ code to generate the result
            state: !lambda |-
              int seconds = round(id(uptime_sensor).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? to_string(days) + "d " : "") +
                (hours ? to_string(hours) + "h " : "") +
                (minutes ? to_string(minutes) + "m " : "") +
                (to_string(seconds) + "s")
              ).c_str();
switch:
  - platform: restart
You haven’t set your below in the middle values, try the following.
      on_value_range:
      - above: 20.0
        then:
          - output.set_level:
              level: 100%
      - above: 18.0
        below: 20.0
        then:
          - output.set_level:
              level: 66%
      - above: 17.0
        below: 18.0
        then:
          - output.set_level:
                level: 33%
      - below: 17.0
        then:
          - output.set_level:
                level: 15%
I have made the requested changes, the darn thing is just flat ignoring the fan speed setting… Also no log entry ever and stuck at 670RPM. Is using a percentage a problem, but I would think it would still log but not set the speed. Converting the percent to decimal did not fix it either.
substitutions:
esphome:
  project:
  on_boot:
    priority: 800
    then:
      - if:
          condition:
            api.connected: null
          then:
          else:
            - delay: 1s
            - output.set_level:
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
api:
  reboot_timeout: 0s
ota:
- platform: esphome
wifi:
  domain: .home
  ap:
dashboard_import:
web_server:
status_led:
  pin:
     number: GPIO2
     inverted: false
i2c:
  sda: GPIO21
  scl: GPIO22
  frequency: 100kHz
output:
  - platform: ledc
    pin: GPIO27
    frequency: 25000Hz
number:
    min_value: 15
    max_value: 100
    step: 1
    optimistic: true
    set_action:
      then:
        - output.set_level:
text_sensor:
  # Send IP Address
    ip_address:
  - platform: sht3xd
    temperature:
      internal: false
#     filters:
      on_value_range:
      - above: 20.0
        then:
          - output.set_level:
              level: 100%
      - above: 18.0
        below: 20
        then:
          - output.set_level:
              level: 66%
      - above: 17.0
        below: 18
        then:
          - output.set_level:
                level: 33%
      - below: 16.9
        then:
          - output.set_level:
                level: .15
    humidity:
      internal: false
    address: 0x44
  # Fan Speed
    pin:
      number: GPIO25
      mode:
        input: true
        pullup: true
    name: PWM Fan RPM
    internal: false
    filters:
      - multiply: 0.5
    count_mode:
    update_interval: 3s
  - platform: uptime
    on_raw_value:
      then:
            state: !lambda |-
              return (
              ).c_str();
switch:
  - platform: restart
You have incorrect indentation for value range
on_value_range:
  - above: 20.0
Also, since you are using number for manual setting I suggest you to use that also in automations. Instead of output.set_level, use:
- number.set:
    value: 66
edit: corrected id:
Requested changes made, compiles and runs but does not change speed…
substitutions:
esphome:
  project:
  on_boot:
    priority: 800
    then:
      - if:
          condition:
            api.connected: null
          then:
          else:
            - delay: 1s
            - output.set_level:
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
  level: DEBUG
api:
  reboot_timeout: 0s
ota:
- platform: esphome
wifi:
  domain: .home
  ap:
dashboard_import:
web_server:
status_led:
  pin:
     number: GPIO2
     inverted: false
i2c:
  sda: GPIO21
  scl: GPIO22
  frequency: 100kHz
output:
  - platform: ledc
    pin: GPIO27
    frequency: 25000Hz
number:
    min_value: 15
    max_value: 100
    step: 1
    optimistic: true
    set_action:
      then:
        - output.set_level:
text_sensor:
  # Send IP Address
    ip_address:
  - platform: sht3xd
    temperature:
      internal: false
#     filters:
      on_value_range:
        - above: 20.0
          then:
            - number.set:
                  value: 100
        - above: 18.0
          below: 20
          then:
            - number.set:
                  value: 66
        - above: 17.0
          below: 18
          then:
            - output.set_level:
                level: 0.33
        - below: 16.9
          then:
            - number.set:
                value: 15
    humidity:
      internal: false
    address: 0x44
  # Fan Speed
    pin:
      number: GPIO25
      mode:
        input: true
        pullup: true
    name: PWM Fan RPM
    internal: false
    filters:
      - multiply: 0.5
    count_mode:
    update_interval: 3s
  - platform: uptime
    on_raw_value:
      then:
            state: !lambda |-
              return (
              ).c_str();
switch:
  - platform: restart
post your log for the sensor output
now this indentation is incorrect
i has to be under m
Fixed the indents…
Logs showing fan speed and temp/humidity.
[18:26:50][D][pulse_counter:181]: 'PWM Fan RPM': Retrieved counter: 1361.82 pulses/min
[18:26:50][D][sensor:093]: 'PWM Fan RPM': Sending state 680.90790 RPM with 2 decimals of accuracy
[18:26:50][D][pulse_counter:181]: 'PWM Fan RPM': Retrieved counter: 1339.11 pulses/min
[18:26:50][D][sensor:093]: 'PWM Fan RPM': Sending state 669.55365 RPM with 2 decimals of accuracy
[18:26:50][D][pulse_counter:181]: 'PWM Fan RPM': Retrieved counter: 1340.89 pulses/min
[18:26:50][D][sensor:093]: 'PWM Fan RPM': Sending state 670.44696 RPM with 2 decimals of accuracy
[18:26:51][D][sht3xd:097]: Got temperature=21.45°C humidity=38.40%
[18:26:51][D][sensor:093]: 'Apple Internal Temperature': Sending state 21.44846 °F with 1 decimals of accuracy
[18:26:51][D][sensor:093]: 'Apple Internal Humidity': Sending state 38.39933 % with 1 decimals of accuracy
[18:26:53][D][pulse_counter:181]: 'PWM Fan RPM': Retrieved counter: 1358.19 pulses/min
[18:26:53][D][sensor:093]: 'PWM Fan RPM': Sending state 679.09454 RPM with 2 decimals of accuracy
[18:26:56][D][pulse_counter:181]: 'PWM Fan RPM': Retrieved counter: 1340.45 pulses/min
[18:26:56][D][sensor:093]: 'PWM Fan RPM': Sending state 670.22339 RPM with 2 decimals of accuracy
[18:26:59][D][pulse_counter:181]: 'PWM Fan RPM': Retrieved counter: 1358.64 pulses/min
[18:26:59][D][sensor:093]: 'PWM Fan RPM': Sending state 679.32068 RPM with 2 decimals of accuracy
Sorry, updated code block.
substitutions:
esphome:
  project:
  on_boot:
    priority: 800
    then:
      - if:
          condition:
            api.connected: null
          then:
          else:
            - delay: 1s
            - output.set_level:
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
  level: DEBUG
api:
  reboot_timeout: 0s
ota:
- platform: esphome
wifi:
  domain: .home
  ap:
dashboard_import:
web_server:
status_led:
  pin:
     number: GPIO2
     inverted: false
i2c:
  sda: GPIO21
  scl: GPIO22
  frequency: 100kHz
output:
  - platform: ledc
    pin: GPIO27
    frequency: 25000Hz
number:
    min_value: 15
    max_value: 100
    step: 1
    optimistic: true
    set_action:
      then:
        - output.set_level:
text_sensor:
  # Send IP Address
    ip_address:
  - platform: sht3xd
    temperature:
      internal: false
#     filters:
      on_value_range:
        - above: 20.0
          then:
            - number.set:
                value: 100
        - above: 18.0
          below: 20
          then:
            - number.set:
                value: 66
        - above: 17.0
          below: 18
          then:
            - number.set:
                value: 33
        - below: 16.9
          then:
            - number.set:
                value: 15
    humidity:
      internal: false
    address: 0x44
  # Fan Speed
    pin:
      number: GPIO25
      mode:
        input: true
        pullup: true
    name: PWM Fan RPM
    internal: false
    filters:
      - multiply: 0.5
    count_mode:
    update_interval: 3s
  - platform: uptime
    on_raw_value:
      then:
            state: !lambda |-
              return (
              ).c_str();
switch:
  - platform: restart
If all indentations are correct, I really don’t know what’s wrong…
Are you getting any errors when you update your code?
Try if it’s triggering on any value:
on_value:
  then:
    - logger.log: "testing..."
The good news is that the above logging method resulted in a log message.
Only explanation I can think of is from documentation:
“This trigger will only trigger when the new value is inside the range and the previous value was outside the range.”
So if there is no change on the values, it doesn’t trigger at all?
Try to manipolate the temperature to output a value that is in different range.
If nothing else works, go with on_value automation and make if-else conditions to change the speed.
I’m done for tonight, good luck!
I did notice something… the code is setting the slider accordingly but not adjusting the fan speed.
This is with the temperature range set to run at full speed.
This is with the range adjusted to run at 66% speed.
Latest version set back up to run on degrees F.
substitutions:
esphome:
  project:
  on_boot:
    priority: 800
    then:
      - if:
          condition:
            api.connected: null
          then:
          else:
            - delay: 1s
            - output.set_level:
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
  level: DEBUG
api:
  reboot_timeout: 0s
ota:
- platform: esphome
wifi:
  domain: .home
  ap:
dashboard_import:
web_server:
status_led:
  pin:
     number: GPIO2
     inverted: false
i2c:
  sda: GPIO21
  scl: GPIO22
  frequency: 100kHz
output:
  - platform: ledc
    pin: GPIO27
    frequency: 25000Hz
number:
    min_value: 15
    max_value: 100
    step: 1
    optimistic: true
    set_action:
      then:
        - output.set_level:
text_sensor:
  # Send IP Address
    ip_address:
  - platform: sht3xd
    temperature:
      internal: false
      filters:
      on_value:
        then:
      on_value_range:
        - above: 72.0
          then:
            - logger.log: "Set fan level 100 over 72"
            - number.set:
                value: 100
        - above: 68.0
          below: 72
          then:
            - logger.log: "Set fan level 66 for above 68 below 72"
            - number.set:
                value: 66
        - above: 65.0
          below: 63.0
          then:
            - logger.log: "Set fan level 66 for above 65 below 63"
            - number.set:
                value: 33
        - below: 63.0
          then:
            - logger.log: "Set fan level 15 below 63F"
            - number.set:
                value: 15
    humidity:
      internal: false
    address: 0x44
  # Fan Speed
    pin:
      number: GPIO25
      mode:
        input: true
        pullup: true
    name: PWM Fan RPM
    internal: false
    filters:
      - multiply: 0.5
    count_mode:
    update_interval: 3s
  - platform: uptime
    on_raw_value:
      then:
            state: !lambda |-
              return (
              ).c_str();
switch:
  - platform: restart
Possibly faulty hardward?
So, it is working… I think I was stuck in a window on boot and therefore the fan speed did not change to the expected speed. Once I raised the temperature of the sensor to the next window the automation took over and it has been working properly. I see no way to force a run through of the conditions at first boot to get the fan speed into regulation…
substitutions:
esphome:
  project:
  on_boot:
    priority: 800
    then:
      - if:
          condition:
            api.connected: null
          then:
          else:
            - delay: 1s
            - output.set_level:
                level: .25 # 100% pwm speed until temp is taken
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
  level: DEBUG
api:
  reboot_timeout: 0s
ota:
- platform: esphome
wifi:
  domain: .home
  ap:
dashboard_import:
web_server:
status_led:
  pin:
     number: GPIO2
     inverted: false
i2c:
  sda: GPIO21
  scl: GPIO22
  frequency: 100kHz
output:
  - platform: ledc
    pin: GPIO27
    frequency: 25000Hz
number:
    min_value: 15
    max_value: 100
    step: 1
    optimistic: true
    set_action:
      then:
        - output.set_level:
text_sensor:
  # Send IP Address
    ip_address:
  - platform: sht3xd
    temperature:
      internal: false
      filters:
      on_value:
        then:
      on_value_range:
        - above: 72.0
          then:
            - output.set_level:
                level: 100%
        - above: 68.0
          below: 72
          then:
            - output.set_level:
                level: 66%
        - above: 65.0
          below: 68.0
          then:
            - logger.log: "Set fan level 33 for above 65 below 68"
            - output.set_level:
                level: 33%
        - above: 63.0
          below: 65.0
          then:
#            - number.set:
#                id: slider
#                value: 25
            - output.set_level:
                level: 25%
        - below: 63.0
          then:
#            - number.set:
#                id: slider
#                value: 15
            - output.set_level:
                level: 15%
    humidity:
      internal: false
    address: 0x44
  # Fan Speed
    pin:
      number: GPIO25
      mode:
        input: true
        pullup: true
    name: PWM Fan RPM
    internal: false
    filters:
      - multiply: 0.5
    count_mode:
    update_interval: 3s
  - platform: uptime
    on_raw_value:
      then:
            state: !lambda |-
              return (
              ).c_str();
switch:
  - platform: restart
That’s what I tried to tell on my last post. Automation starts when the range changes.
Yup and that is why I tried what I did to kick start it. Thanks for the tip!
