I am running OS 6.1 with mqtt addon and just noticed a huge spam load of the following messages:
1624636374: New connection from 172.30.32.2 on port 1883.
1624636374: Socket error on client <unknown>, disconnecting.
1624636494: New connection from 172.30.32.2 on port 1883.
1624636494: Socket error on client <unknown>, disconnecting.
When debugging I found out that that IP is the internal docker IP of the supervisor container running. How and why is this happening? I checked that my mqtt intergration is configured as should which it is. I also check if the node-red node is connected as should which it is.
How can I debug this even more?
