Socket power based on solar, but with timer override
I can figure out the component parts but its the last bit I am having trouble with…
Solar is being monitored using SOLIS, and I have manager to get the BG Smart plugs working I have through Broadcom App…
I can also monitor the solar and trigger the socket based on the generated output so once over a threshold the socket comes on…
What I would really like to be able to do though is track if the switch has not been switched ‘on’ for a period of time and then override the solar and turn it on for a set time anyway.
Ideally this would track both on and off time… As I will be getting the solar to also turn off the switch if the sun drops out.
