Sofabaton X2 setup issue
I’m having an issue when trying to integrate the Sofabaton X2 hub. I have HA running on my QNAP NAS, I downloaded the Sofabaton hub using HACS, and I have MQTT also running on my NAS. When trying to get the Sofabaton activities to load by editing the Sofabaton hub custom card, I can see the hub in the dropdown, but it won’t let me select it. If I try typing in the name of the hub in the editor, it shows an Activities dropdown, but it also shows a spinning wheel like its trying to load, but it never finishes, so I’m stuck. Any suggestions?
Hi @Sir_Goodenough
You appear to have edited the category of this post to Node-RED, but I can’t see anything here that has anything to do with Node-RED. Can you recategorize this post to something more appropriate? [custom integrations perhaps?]
Thanks!
Hi seplant - you may find some help in this discussion, and posting there may get you a response.
There are postings about the X2 hub part way down in that thread.
Sorry, did not intend to categorize under Node-RED (don’t even know what that is). I removed it. Thanks for the suggestion. I’ll check it out.
No problem. It looks like you are new to the forum, and I did not want your posting to get missed!
Postings on mainstream subjects like configuration and templating will be seen by many who may wish to respond. Niche subjects can often get missed in the initial posting, and getting a category or tag means that these posts can be more easily found later. Node-RED is a (very) niche subject area, and I suspect that your particular hardware (Sofabaton) is too.
Searching on the forum first can reveal earlier posts that may help. In this case, there are few posts, but the one I quoted seems recent, and posting on a recent post is much more likely to be seen by the OP and responders - which is the niche community who are probably best placed to help you.
Good luck with your project!
Sorry @Biscuit, must of clicked it wrong.
Thanks for catching.
No problem. You are great at catching many of the uncategorised NR posts to the benefit of us all. Thanks for your efforts. I guessed it was a mis-click and just did not want this post to get lost down the NR rabbit hole, particularly as the OP is a first-time poster.
Tagged your title with the general Third Party Integrations tag so you’ll gain more visibility.
Issue resolved. I did not have any activities loaded on the Sofabaton hub yet, so naturally, HA couldn’t load any activities. Duh!
