Powered through 3.3v, gnd and had sensor has DO and AO. Tried both outputs but still same (no) output when I dip sensor in cup of water and out of water. I checked outputs through multimeter but no mAmps or Volts.
Do I need something different to use this type of sensors?
Sensor is “working”. I get 3.2v when out of (cup of) water and 0.50v when dipped in water.
Perfect. BUT:
When I connect the sensor to my AI of my Esp board (KinCony 868-AIO), then I can’t get any input. And I mean NO INPUT. No change in Volts AT ALL.
My troubleshooting:
I tried a voltage/current generator (https://a.aliexpress.com/_EwgS75o) with external power source and I get voltage measurement on my board (868-AIO), so board is working. Also tried DI and works but that doesn’t matter.
I rechecked my soil sensor output with multimeter (when NOT connected with 868-AIO) and sensor output still works.
I tried to take sensor’s GND both from main GND of board and AI GND. Same result. No input from sensor into board.
I connected the DO of sensor to board and board reacts (change in voltage) to signal. Only of course 2 voltages not an analog out.
I messed around with the potentiometer, still nothing.
I tried external power source to 4volts still the same. No input in any channel I try in the board, normal input on multimeter. Inputs of board working.
My only idea is if I can “multiply” reading of input but does not make any sense.
