Solar assistant
hello, I bought solar assistant and I can’t connect it to home assistant, I have the error “Connection Refused: not authorized”. Has anyone else experienced this? Thanks!
Hi welcome to the forum!
Please, don’t post images from text.
Have you seen this: Home Assistant broker setup with SolarAssistant
Also, is it not possible to integrate your solar setup directly into HA instead of going the long way?
I think many people use Solar Assistant to avoid having to connect to their inverter manufacturer’s cloud service because they don’t know how to build custom hardware to replace the factory Wi-Fi dongles.
I would like help if there is any, to stop using that inverter server, I want to have something fast, not have to wait minutes to find out correctly what values ​​I have on the inverter
Might be to late in your case but proper due diligence BEFORE buying a random inverter does make the difference :tada:
We got ourselves a device that supports local push ( :muscle:) and works 100% offline thanks to an extra $10 invest :money_with_wings:
ok, I’m waiting for your offer, what could I do so I can also use automation for what I need from the inverter.
Simply means your usename/password are not correct
Try with correct credentials? :thinking:
Beside asking good question could also improve your mileage :point_down:
