Solar Edge Integration via Modbus does´nt work
Hi Together,
Can sombeody help me with my SolarEdge integration?
I followed the steps from: Going Green: SolarEdge & Home Assistant | Markus Haack // Software Engineer and the Modbus was integrated sucessfully.
but now I have no data from my PV.
via the standard Solar Edge integration I have data, but this one has not all entitys, that I want
Thanks in Advance
Obvious questions:
  1. Did you enable Modbus on the solaredge?
  2. Can you ping the solaredge?
  3. What does nc tells you?
❯ nc -zv Solaredge.lan 1502
Connection to Solaredge.lan (192.168.3.134) 1502 port [tcp/*] succeeded!
Nothing happend with this ping
Well, then you have your answer.
Or the address you use is wrong, or your solaredge is not connected to your network.
