For my 29 solar panel setup, I made daily resetting utility meters per panel using HA helpers so I coupd track daily generation. For 28 panels it worked perfectly, but one panel is showing super weird readings, and I can’t seem to fix it. Instead of showing 1 to 2 kwh it’s showing thousands of hours, way more than the lifetime power reading that the helper is based on.
In the history panel (not more-info pop-up) what does the history of that panel’s energy consumption (the sensor you used for the utility meter input) look like?
Those are more info pop-ups which I specifically asked you not to use. Use the History panel. The more info graphs show 5 minute statistics. The history panel shows actual state data.
Also you can drag and drop your picture into your forum post.
Go to Developer Tools → Statistics. Look for the panel energy sensor and click on the ramp icon to the right. If you click on the “Outliers” button in that card does it show a wildly high reading at any time?
